ball joints on first gen durango
Old Jan 29, 2010 | 09:44 AM
  #21
Dans01Durango's Avatar
Dans01Durango
I hate it when a bj fails. You have to go around all agitated.
Old Jan 29, 2010 | 12:04 PM
  #22
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
lol, it must be bad . . .
i stil cant believe that i had to point out what i was doing there . . .
Old Jan 29, 2010 | 01:11 PM
  #23
Dans01Durango
Now now, this is a family oriented forum. takes a little bit of quesswork to figure out some double entendres...
Old Jan 29, 2010 | 05:32 PM
  #24
02 Durango_R/T's Avatar
02 Durango_R/T
... and not everyone's mind is in the proverbial gutter ...
Old Jan 30, 2010 | 12:07 AM
  #25
hydrashocker's Avatar
hydrashocker
Mines always there unless drunk.....well never mind!.....
Old Jan 30, 2010 | 12:03 PM
  #26
shrpshtr325
THE ULTI-MOD
soooooo your claiming its never there???????
i think you meant that the other way around, its always there WHEN drunk, bc it seems to be there quite frequently (too frequently for it to be a sober occurrence)
Old Jan 30, 2010 | 02:59 PM
  #27
hydrashocker
That's why I said never mind!.....LOL
Old Jan 31, 2010 | 09:30 PM
  #28
grandpooh's Avatar
grandpooh
Default Ball Joint Recall
My D is a 1999 SLT Plus with the 5.9L (Patriot Blue) & it also had computer problems along with many others. I have replaced Tranfer case, bj(3) times -- upper & lower, shocks, computers (4), tires (3), etc. The dark colored Ds with the 5.9L engines do not have enough air flow in the engine compartment to cool the PCM, and I also noticed that when the sun loads up and conducts heat directly to the inner fender bracket for the PCM, it melts the contacts for the PCM and they go out every 40K miles or so. I simply after replacing my PCM last time bought (3) larger PCM bolts, plus (6) nylon washers from my local hardware store and separated the heat source from the bracket. In addition, I hooked up a computer high speed fan and ducted some down spout hose from the front of the grill to the PCM to cool it while sitting in that heat in the summer. Everything works good now. I did notice Dodge changed the connection points on future PCMs due to heat.
Originally Posted by IndyDurango
gargle,
Glad to hear you got it all taken care of. There are posts on the internet where entire front tires have broken off while driving. Some of the same posts and crying at Dodge as at fault when in reality the recall was/is very common knowledge. It is up to folks to do exactly what you did... just get it done. I agree 100% and the safety of the family being the most important thing!
What year is your D?
IndyDurango
Old Feb 3, 2010 | 07:37 PM
  #29
Khayman's Avatar
Khayman
I recently replaced my shocks in my durango, and I am now experiencing a clunking noise in the front suspension. A buddy of mine thinks it is the ball joints, does that seem reasonable, or should I be looking at something else? I have a 2001 Dodge Durange R/T 5.9L. I had the recall done on the ball joints in 2004, and I only have 79k miles on the Durango. The clunking is coming from the drivers side, and that shock was the worst one.
Any help is appreciated.
Thanks
Old Feb 3, 2010 | 11:16 PM
  #30
IndyDurango's Avatar
IndyDurango
Uh... loose shock?
IndyD
