Heat coming out barely warm
Old 01-13-2010, 12:29 PM
Duranged408's Avatar
Duranged408
Duranged408 is offline
Originally Posted by mark38090
Duranged408, It was suggested by the guy that runs our motor pool at work to do similar by just doing the heater core, but he suggested using CLR or Lime Away. Said that's what they do to the vehicles at work. When I tried to flush the whole system the other night it was nasty, very nasty. So other than the what to flush the heater core with that sounds like a good idea. Any thoughts on the CLR or Lime Away?
Its a 50/50, ive never used clr in that kind of instance. I didnt like its performance on the household chores But if it works, hell worth a shot.
  #22
Old 01-13-2010, 07:05 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Well you have aluminum in the motor and I think it eats it. One problem I also see is that things could detach and end up in your radiator or core.
I don't know about the idea?
  #23
Old 01-13-2010, 07:37 PM
Duranged408
We are talking about isolating just the heater core and chem flushing, no engine involvement. If the heatercore replacement was already in the plans, testing a little before commiting $400+ on a core wont hurt. He knows that the HC must be flushed and neutralize with baking soda to remove all the chems so it would never get to the engine. CLR is a little caustic, but as some mentioned take a piece of foil, put it in a dish, let it sit. 20 minutes to 2 hours nothing would happed
  #24
Old 01-14-2010, 05:26 PM
hydrashocker
Makes sense. Give it a try!
  #25
Old 02-09-2010, 11:53 PM
Okiefromwatonga's Avatar
Okiefromwatonga
Okiefromwatonga is offline
dumb azz noob question but what about plain 'ol vinegar to flush the core, if it works for clearing hard water deposits out of my shower head wouldn't it do the same for the HC?
  #26
Old 02-10-2010, 12:30 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
How are you going to get the vinegar to the core? You going to run it through the entire motor via the radiator?
Quick Reply: Heat coming out barely warm
