2000 Durango Lights Flash when unlocked and locked with Key FOB??
ok here it is, since i dont have a scanner i have to type it out for ya, you owe me for this BTW!!!!!!
1. Enter your vehicle and close all doors
2. Fasten your seatbelt (this turns off any possibly confusing chimes during the procedure)
3. Place the key in the ignition
4. Turn the ifnition to the ON position (do not start the truck)
5. Press and Hold the LOCK button on the key fob
6. After holding the LOCK button for four seconds also press the PANIC button within 6 seconds
7. When a single chim is heard, release both buttons.
8. Turn the ignition OFF to test the horn chirp feature
9. To reactivate this feature repeat the above steps.
10. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the above procedure
direct from the 02 owners manual
