rear wiper...?
Old Jan 10, 2010 | 11:17 AM
jjhalo's Avatar
jjhalo
Default rear wiper...?
Hey guys, so I went to replace my rear wiper blade on my '01 4.7 and I cant find one that will hook on corectly. The wiper will slide on fine but it wont secure. Whats up?
Old Jan 10, 2010 | 02:26 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
save yourself the hassle and just replace the rubber blade part of it and save the frame . . . the guy where i buy them sells ANCO products, and changes them for free when you buy the rubber, he broke mine but had one that fit . . . i still say change the rubber piece and be done with it
Old Jan 10, 2010 | 04:53 PM
hydrashocker's Avatar
hydrashocker
Read the directions in the box for the correct style setup.
Old Jan 11, 2010 | 12:05 AM
jjhalo's Avatar
jjhalo
I would just change the rubber part but the frame cracked so thats not an option, and Hydra...I tried two different brands of wiper, none had the right pieces to hook it up with.
Old Jan 11, 2010 | 09:23 AM
shrpshtr325
THE ULTI-MOD
http://napaautoparts.com/Search/Deta...+50022+2022007
that looks like the one i got, ill take some pics for ya once i get all the way awake
Old Jan 11, 2010 | 10:28 AM
Dans01Durango's Avatar
Dans01Durango
Orrr.... You can do what I did, replace the whoel assembly and install a Gen2 rear wiper.
Old Jan 11, 2010 | 11:12 AM
shrpshtr325
THE ULTI-MOD
hey dan, ill buy the parts, and you can come do mine, ok
Old Jan 11, 2010 | 11:18 AM
Tizzy1's Avatar
Tizzy1
The blade clamps to the arm, you have to lift the little lever and slide the blade out of the clip. I don't know if the aftermarket makes a connector like it since it is so little used. You may be stuck buying the part from the dealer.
Old Jan 11, 2010 | 11:38 AM
Dans01Durango
LOL! Still trying to get me into jerzey??? I thought you were #2 on the rear wiper club. That's according to your sig!
Old Jan 11, 2010 | 11:41 AM
Dans01Durango
Actually, jj. The aftermarket wipers do come with all the necessary adapters for you to mount the new blade assembly. I used anco 16" blades for the back and I had no problems attaching them.
