Has anybody had luck on a 4.7 crank pulley?
You need to use a 3 finger gear puller and thoroughly clean it first.
CRANKSHAFT OIL SEAL -
FRONT
REMOVAL
(1) Disconnect negative cable from battery.
(2) Remove accessory drive belt (Refer to 7 -
COOLING/ACCESSORY DRIVE/DRIVE BELTS -
REMOVAL).
(3) Remove A/C compressor mouning fasteners and
set aside.
(4) Drain cooling system (Refer to 7 - COOLING -
STANDARD PROCEDURE).
(5) Remove upper radiator hose.
(6) Disconnect electrical connector for fan mounted
inside radiator shroud.
(7) Remove radiator shroud attaching fasteners.
NOTE: Transmission cooler line snaps into shroud
lower right hand corner.
(8) Remove radiator cooling fan and shroud (Refer
to 7 - COOLING/ENGINE/RADIATOR FAN -
REMOVAL).
(9) Remove crankshaft damper bolt.
(10) Remove damper using Special Tools 8513
Insert and 1026 Three Jaw Puller (Fig. 64).
INSTALLATION
CAUTION: To prevent severe damage to the Crankshaft,
Damper or Special Tool 8512, thoroughly
clean the damper bore and the crankshaft nose
before installing Damper.
(1) Using Special Tool 8348 and 8512, install
crankshaft front seal (Fig. 66).
(2) Install vibration damper (Refer to 9 - ENGINE/
ENGINE BLOCK/VIBRATION DAMPER - INSTALLATION).
(3) Install radiator cooling fan and shroud (Refer
INSTALLATION).
(4) Install upper radiator hose.
(5) Install A/C compressor and tighten fasteners to
54 N·m (40 ft. lbs.).
(6) Install accessory drive belt refer (Refer to 7 -
INSTALLATION).
(7) Refill cooling system (Refer to 7 - COOLING -
(8) Connect negative cable to battery.
FRONT
REMOVAL
REMOVAL).
set aside.
REMOVAL).
INSTALLATION
INSTALLATION).
INSTALLATION).
