air and heat
Old Jan 31, 2010 | 08:18 PM
backwallkiller's Avatar
backwallkiller
Default air and heat
why does it smell like anti-freeze when i run my ac?
Old Jan 31, 2010 | 09:50 PM
hydrashocker's Avatar
hydrashocker
Your heater core might be leaking.
Old Jan 31, 2010 | 10:21 PM
backwallkiller
if it was leaking would the carpet be wet? thats why i wasnt sure what it was because it aint wet and i dont see any anti-freeze comen out anywhere
Old Jan 31, 2010 | 11:02 PM
IndyDurango's Avatar
IndyDurango
it is going out the drain hole on the firewall side.
no other reason to small af other than a leak.
IndyD
Old Jan 31, 2010 | 11:28 PM
tm985's Avatar
tm985
Every once in a while I get a smell and I'm not sure if it's antifreeze or not but when I went to get my oil changed they did say that it took some coolant and to keep an eye on it. I haven't really noticed any leaks or anything on the ground so I'm not sure what it could be.
Old Feb 1, 2010 | 11:54 PM
hydrashocker
I smell it but my core is going out.
Old Feb 2, 2010 | 12:32 AM
tm985's Avatar
tm985
What does this mean?
Old Feb 2, 2010 | 05:56 PM
hydrashocker
I can smell antifreeze, but then again my heater core is leaking and needs replaced.
Old Feb 3, 2010 | 09:35 PM
tm985's Avatar
tm985
you don't sound too concerned?
Old Feb 3, 2010 | 11:18 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
long as its not a fast leak and he carries a gallon of 50/50 with him to keep it topped off there isnt anything to worry about except the smell and wetness
