Help Plzzz
Old Feb 1, 2010 | 12:11 AM
fisheye1's Avatar
fisheye1
Default Help Plzzz
Hey guys new to the forums just wondering - I have a 1998 5.2 Durango and the tranny is slipping wondering if the 4.7L tranny will work?
Old Feb 1, 2010 | 12:49 AM
IndyDurango's Avatar
IndyDurango
No it will not.
Just get yours serviced. Slippage is common when not properly serviced. Drop pan (never flush), drain, replace filter with Mopar replacement and most importantly, adjust the bands, change fluids. Slippage gone as long as the trans isn't toast.
IndyDurango
Old Feb 1, 2010 | 08:03 AM
Dans01Durango's Avatar
Dans01Durango
What he^ said.
Old Feb 1, 2010 | 02:42 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by IndyDurango
No it will not.
IndyDurango
+10000
the 4.7 and 5.x used different transmissions and are not compatible with each other
Old Feb 2, 2010 | 12:01 AM
fisheye1's Avatar
fisheye1
Default :(
Actually noticed today i have no 2nd gear
Old Feb 3, 2010 | 12:46 PM
fisheye1's Avatar
fisheye1
Default ??
Anyone have any idea's or am i stuck rebuilding the transmission?
Old Feb 3, 2010 | 02:12 PM
Spc_Sapper's Avatar
Spc_Sapper
to be honest man it looks liek your SOL
Old Feb 3, 2010 | 04:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
fisheye1
You need to start with the basics,ck fluid....low add and drive and verify no 2nd gear, is the ck engine lite on? Do you know if the transmission starting off in 2nd gear instead of 1st. this happens alot when the governor sensor goes bad. Drop the pan and inspect for lots of metal, a little is okay. ck band adjustments and replace the filter and sensors if you want too. Here is a easy way to see if you are starting off 2nd. Put the lever in drive and start off, then come to a stop and move the lever in low gear range. If you notice a big diff the way it start off, the problem is with the valve body and again maybe just the sensors. Also ck your kick down cable to for adjustment. This also known as T.V. cable and throttle pressure cable. You need to do these first and maybe save some money from a overhaul or just have it replaced.
