Heater switch
Old Feb 1, 2010 | 02:31 AM
zootzee's Avatar
zootzee
Default Heater switch
Since I bought my Durango the the highest level of the heater switch never worked. But now the second highest isn't working.
So could this be the switch, relay, or the heater motor?
It's cold outside and I don't want the heater to die all together. I'm just glad my heated seats are working.
Any help would be great.
Thanks all
Old Feb 1, 2010 | 07:52 AM
Dans01Durango's Avatar
Dans01Durango
You can look at the DIY section on the first page under "fan blower motor resistor fix". HTH.
Old Feb 1, 2010 | 10:05 AM
IndyDurango's Avatar
IndyDurango
Blower resister. Easy fix on a 2001-2003 D, not so easy on a 1998-2000 D.
IndyDurango
Old Feb 1, 2010 | 02:45 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
blower motor resistor, classic symptoms $15 US at the dealer
Old Feb 1, 2010 | 08:07 PM
zootzee's Avatar
zootzee
I found this link but it will not open.
https://dodgeforum.com/forum/692-dur...er-switch.html
is there another link that gives a how to?
Thanks
Old Feb 1, 2010 | 10:12 PM
IndyDurango
What year is your Durango? That was we can send you to the right instruction set.
IndyD
Old Feb 2, 2010 | 12:13 AM
hydrashocker's Avatar
hydrashocker
Thanks
Here's the links:
Fan Motor Blower Resistor Fix
https://dodgeforum.com/forum/1st-gen...er-switch.html
1998-2000
https://dodgeforum.com/forum/1st-gen...istor-fix.html
https://dodgeforum.com/forum/1st-gen...r-problem.html
2001-2003
Old Feb 2, 2010 | 12:36 AM
IndyDurango
HS,
Links no workie. The big font one does, the rest do not.
Also, the last one says 2000-2003... if so... it is incorrect. The breakdown for the differences is 98-00 under the cowl and then 01-03 under the glovebox.
IndyD
Old Feb 2, 2010 | 06:11 AM
zootzee's Avatar
zootzee
It's a 2003
thanks
Old Feb 2, 2010 | 06:37 PM
hydrashocker
Try the links now!
