sludge 2000
Old Mar 16, 2010 | 10:08 AM
esdaddy's Avatar
esdaddy
Default sludge 2000
Hey guys been reading about sludge cause i got sludge in the oil filler neck,... its pretty bad.. the guy told me it was due to the pcv valve it was stopped up with sludge of course since its coming right out of the neck ,,i run mobil one and change it about every 3500-4000 miles..... i had it flushed out that last time... any suggesttions... i have right at 100k on it thanks
Old Mar 16, 2010 | 01:24 PM
Duranged408's Avatar
Duranged408
Sludge being farse, i'll bet you own a 4.7L.
Its nothing to stress about, but for your comfort
ACCUMULATION OF FOAMY OIL EMULSION 4.7L ENGINE OIL FILL HOUSING
Date: 09/11/00 (02/00) -- Bulletin # 090100A (supercedes 090100)
Model year(s): 1999-2000
Description:A customer may complain of an oil emulsion accumulation inside the engine oil fill housing. The oil emulsion will normally be foamy and be gray or light brown in color. The emulsion accumulation will often occur on cooler engine surfaces, like the inside of the oil fill housing. Modern engine oils are designed to address the oil emulsion phenomenon. Oil emulsion accumulation is normal and will not damage the engine A new baffle and a revised oil fill housing cap have been released. The baffle and oil cap will help to reduce the amount of oil emulsion accumulation within the oil fill housing.
Details: If the customer has experienced this issue, then perform the Repair Procedure.
Parts required:
53032126AA Baffle, Oil Fill Housing
53032389AC Cap, Oil Fill Housing
Old Mar 16, 2010 | 08:41 PM
IndyDurango's Avatar
IndyDurango
+1 D408 (of course)
esdaddy, don't confuse emulsion (commonly referred to as 'snot' in your lil'4.7l) with sludge. There is a B-I-G difference. Your issue is treatable... REAL sludge is not. Fortunately, you do NOT have sludge based on your description. See post above for the correct assessment and solution.
IndyDurango
Old Mar 16, 2010 | 11:15 PM
hydrashocker's Avatar
hydrashocker
There goes that word again........
Old Mar 17, 2010 | 09:46 AM
Dans01Durango's Avatar
Dans01Durango
What word?... Emulsion?...
Also +2 D408
Old Mar 17, 2010 | 02:24 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+3 on D408, and i think im watching the google hits on the thread go up
Old Mar 18, 2010 | 01:05 PM
sltplus2000's Avatar
sltplus2000
Old Mar 18, 2010 | 11:29 PM
hydrashocker
Originally Posted by sltplus2000
unfortunately for some people like me with no knowledge on car repair will go to google for answers and all you can find is the complaines about such and such of Dodge. Thats how I find out about sludge in the engine but turns out like Hydra and Indy explaine is just Snot
Now there's no need to get ignorant. We are simply stating there is a difference in these words.
What you are describing is a emulsification only located in the oil filler tube with the (4.7L only) that had a TSB (Technical Service Bulletin) Bulletin # 090100A that you can search or Google to see what to do to fix it. Excuse our ignorance in this word but we hear it over and over but and have tried for years to get it vanquished.
Old Mar 19, 2010 | 12:07 AM
45AutoPete's Avatar
45AutoPete
Hey I was looking down the oil fill tube and......aaaaaaachoooooooo.........dammit.....SNOT !! I mean emulsified oil lingers in there. On the serious side, will changing the PCV Valve help to subside this?
Old Mar 19, 2010 | 10:49 AM
Dans01Durango
Read D408's post about the fix for emulsion.
