Had a CEL come on today
I have a 2002 Durango 4.7 engine. I had the check engine light on and it had the evap codes. 0455, etc. I went underneath the vehicle and the evap charcoal canister had crack, brittle and one disconnected hose. I changed the hoses and now it runs rough but not to rough and it stall sometimes when the engine is cold. Did I do something wrong?
All I did was replaced the hoses. The check engine light is off, but the vehicle runs a little rough. Still drivable. Did the computer 30 second disconnect the negative test.
No codes, no check engine light but the rough idle when I first start it or step on the gas stalling. Any advice will be appreciated!
Thank you!
Sakimoto321
Thank you!
Sakimoto321
