Engine stalls when I shift from Drive to Park
Old Mar 28, 2010 | 11:23 PM
hydrashocker's Avatar
hydrashocker
You could also try to place a cold pack on the PCM when you leave it in the parking lot then come back quickly and see if it starts (seeing if the PCM is getting hot or not) which means a bad PCM if heat causes the issue.
^ Indy has a great idea as well. ^
Old Apr 4, 2010 | 08:10 PM
nordic's Avatar
nordic
Just an update...
This weekend I cleaned out my throttle body...I'd never done so before (65,000 miles+) and the IAC plunger was pretty grimy. My truck runs much better now & is not stalling anymore when I shift into Park.
Not sure if this is a temporary fix or not...but my truck runs great now. Hopefully it stays this way.
Old Apr 5, 2010 | 09:47 PM
hydrashocker
Thanks for the update!
Old Apr 21, 2010 | 12:01 AM
mike71098520's Avatar
mike71098520
i have the same issue... im gonna clean my throttle body tomorrow morning, but the IAC plunger? is that the same thing as the IACV? if so i know what that is. thanks ahead of time!
Old Apr 21, 2010 | 03:51 PM
hydrashocker
yes..
