trailer wiring
Old Mar 31, 2010 | 12:44 AM
hydrashocker's Avatar
hydrashocker
Originally Posted by shrpshtr325
hydra, you should be using firefox as your main browser, its what all the smart(sober?) ppl do
I do use it even when sober.
Old Mar 31, 2010 | 12:49 AM
Dans01Durango's Avatar
Dans01Durango
hmmm thats odd did you click open when the download option came up or did you save it to your hard-drive then try opening it hydra, does it work for you or do i need to upload it again?
Shrps, you still drunk??? I think tattood is the one who can't open the link. hydra is doing fine.
Old Mar 31, 2010 | 05:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i know hydra is not the on e having problems, i wanted to see if anyone else could open it bc i have no problems with it, so if hydra or you could open it, then the file is fine on the server
Old Mar 31, 2010 | 11:42 PM
Dans01Durango
Actually, I use IE and it opened fine for me...
Old Apr 4, 2010 | 02:55 PM
tattoodbrute's Avatar
tattoodbrute
ok got it open with new version of adobe, but i need the wiring at the taillight what each color is, its weird have the 50 amp fuse in the distrabution center but no harness anywhere there is a plug beside the DC not sure what it is though
Old Apr 4, 2010 | 04:26 PM
hydrashocker
There's a 15 amp fuse in the junction box (dash fuse panel). If you are asking about the panel behind this panel that is where there is a cigarette lighter, power outlet fuse and not sure the other 2 as there is 4 fuses back there.
VT/BK.......+ Backup lamp.
BK...........Ground
BK/YL.......Driving Lights
WT/TN.....Hi mount brake light
LG...........Drivers Stop Turn
TN...........Pass Stop Turn
I had to look in multipule Service Manuals for this as that don't look right. In the 2000 Dakota Service Manual it states that the Right and Left stop turn are DG/BR but have different colors before the switch DG/RD Drivers and BR/RD pass. You will have to see what you have.
Old Apr 4, 2010 | 04:29 PM
hydrashocker
You couldn't find the OEM trailer wires back by the spare tire frame area on the drivers side?
Old Apr 5, 2010 | 08:57 PM
tattoodbrute
no its not there i find it weird cause the distrabution center has a 50 amp fuse in place for the trailer wiring but no plug anywhere
Old Apr 5, 2010 | 09:00 PM
tattoodbrute
BK...........Ground
no i was talking about beside the battery the main dist.center has a 50 amp fuse for a woring harness, but i'll check what i have for colors i guess i'll have to run a wire to the pass. side as well for that turn signal
Old Apr 6, 2010 | 12:30 AM
hydrashocker
Originally Posted by tattoodbrute
hello all, new here, just picked up a 2000 durango 4.7, just put a trailer hitch on now can't find the wiring harness, or where do i splice a connector to or hook a factory one to thanks in advance
You basically state in this post that you did NOT have a tow package installed and that you installed a receiver. Now your sayin that there is a towing relay???? I'm REALLY lost! Whats the question here????
