Strange electrical gremlin
Hi all, i am new to this forum & have an electrical question for the brain trust here.
I hope this has not been asked 1000 times, or if it has, then maybe you have the answer for me.
I am having an issue with what i think is the "door open" sensor, the symptoms are as follows:
Maybe once a day, when i turn the car on, the interior lights won't turn off, the headlights turn on, and the "door open" light is on the dash.
When i turn the car off the door dinger dings as if i left the lights on.
If i disconnect the battery for a second, then reattach the neg. it resets & i'm good for a day or so.
Is there a sensor that could be failing, & if so where is it? I really hope it's not in the nether regions of the dash.
Any help would be appreciated
Thanks,
Brent
Thanks,
Brent
Central Timing Module (CTM)
It is located under the drivers side kick panel (by the E-brake) but you have to have a dealer flash it with your vehicle info. You must also take BOTH your key Fob's in to have them flashed into the new CTM so your Fob's will work unlocking the door. I've heard if you have the dealer do the whole thing your talking around $450.
Trending Topics
