omg plz help
Old Apr 9, 2010 | 06:46 AM
Duranged408's Avatar
Duranged408
The 5.9 will run on a 5.2 comp, just not to its full potential. Flashing is usually not done in favor of just picking up a mp360 comp that will add more pick me up and support some mild mods (cams/heads/etc/littlestuff)...
5.2/5.9 swaps are straight foreward plug and play other than some balancing/flxplt work, i dont see how you could mess it up unless faulty hardware on the donor or you hooked up the sensors wrong.
What year rango and donor?
Old Apr 10, 2010 | 12:45 AM
hydrashocker's Avatar
hydrashocker
I wouldn't have thought they would run on the same PCM?
Old Apr 13, 2010 | 07:02 AM
Duranged408
5.2 to 5.9 eng will work, but its not feeding the full potential to the eng. as the settings are derived for the lesser 5.2. While it does counter act the swap, it can be used until the purchase of a 5.9 set.
Old Apr 13, 2010 | 09:42 PM
hydrashocker
Just learned something new......Thanks!
