cummins 5.9 durango
if your interested i have a 97 12v for sale the motor is good as well as all the running gear there is no interior and the wiring harness is no good it got submerged in water i spent two weeks flushing all fluids idk how but there was no water in the tranny or axles only the motor but i hooked it up to a new battery and starter and it fired right up... it took two hundred bucks in oil before i even tried cause i wanted no chance of it hydro locking on me
iters???(think you meant tires)
and if that is what he did then he also lowered the suspension, bc that truck is not riding high enough to be on a any ram chassis, it looks to me like the tires are sticking out bc they are wider than stock, and he has aftermarket rims which might be necessary to push the tires out to allow the much larger 5.9 I6 diesel to fit under the hood
