Oh NO!!! Transfer Case, Tranny or???
Old Apr 20, 2010 | 01:27 PM
rjmannex's Avatar
rjmannex
Unhappy Oh NO!!! Transfer Case, Tranny or???
OK, so the other day my daughter was driving when "all of a sudden" my Durango wouldn't go into reverse...funny "all of a sudden" would probably have occurred going forward...anyway. She drove it home and explained that she put it into reverse and it made a screeching sound. I put it into reverse and got the very definate thud of it switching into reverse but no movement. I gave it just a few RPM's and it creeped a couple of inches then I got a loud metallic sound.
It goes forward just fine...of course, the powertrain warranty just expired.
Tranny, transfer case or...ideas???
Old Apr 20, 2010 | 06:39 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
what engine and trans do you have, what year is your truck and how many miles on it???
sounds to me like you will be rebuilding your transmission the 42 and 44 re transmission (and the 46 too given poor enough maintenance) tend to go bad and for some reason reverse tends to be the first to go . . .)
Old Apr 20, 2010 | 10:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
The reverse piston may have broke and banging around in the servo bore. You need to drop the pan, if you have a 44 or 46RE trans,and inspect.
Old Apr 20, 2010 | 11:20 PM
hydrashocker's Avatar
hydrashocker
Sounds like a transmission.
Old Apr 21, 2010 | 11:26 AM
rjmannex's Avatar
rjmannex
Default oh...
sorry, I didn't list...it is a 2003 with the 5.9 and a whopping 54k on it! I put it in the garage last night, and on the smooth surface it will creep in reverse a little. Never heard the noise again except for the one time...
Old Apr 21, 2010 | 01:54 PM
Dislander's Avatar
Dislander
I'll toss this out as I just finished fixing a full size that had a somewhat similar issue.
The pinion nut had worked loose allowing the pinion gear to be pulled in far enough to stop the truck from moving more than a few inches in reverse but would drive forward with no real issue, though I imagine it had a hell of a vibration if driven at any speed.
The cut of the gear forced the pinion to proper position forward & sucked it into the housing till it contacted the carrier binding the rear end in reverse.
My customer swears his diff has never been apart & his truck though a 99 has only about seventy k.
It was so close to what you described I figured I share.
Old Apr 21, 2010 | 03:55 PM
hydrashocker
That is a strange one.
How much you charging for the rebuild and parts needed?
Old Apr 21, 2010 | 10:49 PM
master tech
If the transmission is creeping in reverse, the damage may have already been done. Hook up a pressure gauge the line pressure port for reverse and see what your pressure reading is. You should be around 200 to 220 PSI.
Old Apr 21, 2010 | 11:40 PM
Dislander's Avatar
Dislander
Not sure on the parts but I charged about 400 to do the work. I let some customers provide their own parts but I think two hundred would have been right. that includes replacing eight brgs, three seals a crush-sleave & new pinion nut. I tossed in the locktight for free.
he was lucky though, only some minor dings & chips on the pinion & carier. customer elected to have me dress those rather than replace & all is well at this time.
Old Apr 21, 2010 | 11:45 PM
master tech
Did you had to add or remove a shim for the pinion depth?
