What engine will fit?
Apr 26, 2010 | 03:55 PM
I have an 02 D with the 4.7L engine. I am thinking of putting a bigger power plant in and I was wondering what is available that will bolt right in.
Paul in Pa
Apr 26, 2010 | 06:33 PM
Nothing will directly fit unless it is another 4.7 engine. Do a search on that and you will see for yourself.
Apr 26, 2010 | 06:43 PM
Apr 26, 2010 | 08:38 PM
if you want to only replace the engine then a 4.7 must be used to replace a 4.7
if you dont mind doing a transmission/t-case/engine swap you could go with a 5.9 or even a 5.7 if you are brave enough
Apr 27, 2010 | 12:35 AM
Better off staying with the 4.7L
Apr 27, 2010 | 12:42 AM
Errr.
The same trans is in the 5.7L HEMI as the 4.7l. You can do a HEMI swap with wiring, PCM and mounts if so inclined.
With that said, sell it and buy a 5.9L instead if wanting a Gen1 or a 5.7L in a Gen2.
IndyDurango
Apr 27, 2010 | 07:54 PM
Quote:
Originally Posted by
IndyDurango
Errr.
woops, you are correct, i forgot about that
Apr 27, 2010 | 09:40 PM
I didn't forget, I just wanted to see Indy show his colors.....LOL
Apr 28, 2010 | 12:11 AM
Apr 28, 2010 | 12:26 AM
If it is doable, I would not mind swapping out the old 4.7l for the modern 4.7l that can put out over 300hp.
