4.7 head removal
Old Aug 4, 2010 | 03:07 AM
  #31
rusmannx's Avatar
rusmannx
tonight i took it out for a ride (yay), only to have it over heat after about half a mile (boo).
the temp gauge shot up quickly and the coolant in the tank started to bubble. however, cranking up the hot air resulted in just.... air. not hot. weird.
i must have a line crossed or something. prior to taking the motor apart i had put about 50 miles on it without any issue.
anyone have an idea? maybe something obvious?
edit: NEVER MIND
i'm an idiot. i called a friend of mine and told him the story and he said "air bubble". yup, i didn't add coolant through the upper hose, just the coolant tank. it took nearly two gallons and suddenly, amazingly hot air from my vents.
again, i'm an idiot.
Old Aug 4, 2010 | 03:19 PM
  #32
hydrashocker's Avatar
hydrashocker
It happens to all of us......LOL
Be VERY careful NOT to over heat that motor!
Old Sep 18, 2010 | 03:33 PM
  #33
stratuser's Avatar
stratuser
Need help! I can't find the tool needed to install the vibration damper. This is for the 4.7L engine. I tried a installer kit but it will not work. Is there a special tool for this? Thanks for your help!
Old Sep 18, 2010 | 10:21 PM
  #34
hydrashocker
It should just set on the key way and drive nut down. I cant get to my info right now sorry?
Old Aug 5, 2011 | 10:32 PM
  #35
jim1999's Avatar
jim1999
Thumbs up
what is the proceedure for setting the 4.7 at TDC? I am getting ready to do my timing chain? Russman, did you go with the Cloyes kit 9-0393s with sprockets and all? thanks
Old Aug 6, 2011 | 04:38 PM
  #36
hydrashocker
If you look down at the crank shaft on the drivers side is a arrow. On the pulley is a mark that has before and after degree markings, the center is TDC which is 0 degrees. Now the next thing you do is turn the motor by hand by placing a wrench on the center nut of the crank shaft and turn clockwise, never turn counter clock if you miss it keep turning. Once you line them up take out the front drivers side spark plug and ensure the piston is all the way up at the top, if not then you are 180 degrees off and you need to turn the motor by hand one more time back to TDC and you now should have the piston at the top. You can place a long screw driver down the plug hose to see if it is up to the top.
Old May 19, 2012 | 05:09 PM
  #37
tinbanger's Avatar
tinbanger
Originally Posted by hydrashocker
1. No on the guides.
DESCRIPTION - VALVE GUIDES
The valve guides are made of powered metal and
are pressed into the cylinder head. The guides are
not replaceable or serviceable, and valve guide reaming
is not recommended. If the guides are worn
beyond acceptable limits, replace the cylinder heads.
2. Cams should be reusable.
Should just need the sprockets, chains, and tensioner.
You really need to download a Service Manual: http://pdftown.com/Dodge-Durango-Service-Manual.html
i down loaded the manual, and all of the files are password protected. do you know the password?
Old May 19, 2012 | 05:27 PM
  #38
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check the FAQ thread, it as links to freely available copies (no password required)
Old May 19, 2012 | 07:11 PM
  #39
tinbanger's Avatar
tinbanger
ok i must be blind cause i cannot seem to find the FAQ section, can u please point me in the right direction. thanks
Old May 20, 2012 | 08:38 AM
  #40
shrpshtr325
THE ULTI-MOD
its a thread stickied to the top of the 1st generation page, it is NOT its own section
EDIT: here https://dodgeforum.com/forum/1st-gen...wers-faqs.html
