Any Suggestions?
Old May 5, 2010 | 02:13 AM
cjwillfixit's Avatar
cjwillfixit
Default Any Suggestions?
Will post complete project at another time....'99 SLT 5.9 4X4.....
Aftermarket wheels with a bit of a problem...see pics....
Attachment 8649
Attachment 8650
Attachment 8651
Old May 5, 2010 | 09:49 AM
IndyDurango's Avatar
IndyDurango
Wrap the lug in 2 or 3 folds of tin foil, then remove. Unsuccessful, wrap again with another layer and try again.
Throw them all away with the key and buy new OR at a minimum buy a new key. It will have been damaged too.
Next time, make sure the key is fully seated and flush/level when removing. Any angle on a breaker bar, lug wrench or impact and that nut is done.
IndyDurango
Old May 5, 2010 | 10:38 AM
shortyR6's Avatar
shortyR6
i have banged sockets over stubbern wheel lugs to get them off.
Old May 5, 2010 | 09:10 PM
hydrashocker's Avatar
hydrashocker
Both of those are GREAT ideas! +1000
Old May 6, 2010 | 10:21 AM
cjwillfixit
I appriectiate the response & ideas, however i may have not been clear. These are solid one piece lugs, not the ones with that damb cap that always comes off. Wish it was.
The cone is still on & tight. With no hex to grab......Irwin makes a bolt grip tool, but i only have room for 1 1/8" O.D. tool to get in there. Sure enough, the size to "fit" is 1 1/4" O.D. I'm sure there is one out there, just not here in Hicksville.
Will be banging sockets, last resort DRILL!!
Wish me luck & Thanks for the reponses & ideas.
All this to gain access for freeze plug leak..............one seems to lead into another on this project!
Jim
Old May 6, 2010 | 07:05 PM
hydrashocker
The only thing I could tell you is to chisel some groves on it enough to really hammer a socket on there and have enough to wall to grab on to it. Once I had to chisel a side completely off until it cracked. Then I put a socket on it and it backed right off.
Old May 7, 2010 | 12:40 AM
IndyDurango
You were clear. The suggestions were clear.
Foil will get it usually. A smaller hammered on socket will too. Just get it done.
IndyD
Old May 7, 2010 | 09:28 AM
cjwillfixit
Well, Got it. I talked my local tire shop again, he let me borrow bolt grip deep well they have. Hammer just enough to get a bite & off it came!
May be a worthy tool investment.
Thanks Again,
Jim
Will post pic later.......
Old May 7, 2010 | 01:07 PM
hydrashocker
Great!
I never put full Torque on the locks just in case.
