2000 Durango 4WD Shift lever.
Old May 19, 2010 | 07:13 AM
tvogel's Avatar
tvogel
Default 2000 Durango 4WD Shift lever.
Hello all. I was recently Changing the oil in my 2000 Durango SLT and when I was underneath removing the skid plate i saw what appeared to be a bracket hanging down. Upon further inspection I realized it was the linkage to the 4WD shift lever. I could put it back in the connector but it would not stay and I did not see how it stayed in there(clip etc.) There was a rubber tip but that was it. Any ideas? Thanks.
Old May 19, 2010 | 07:40 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it should be held in place by a rubber bushing iirc, might need to get a new one
Old May 19, 2010 | 10:34 AM
tvogel's Avatar
tvogel
shrpshtr325,The bushing is still there. But what holds it in place? I can put it back in but it will come right out. I wrapped a piece of wire around it for now but want to fix it right.
Thanks
Old May 19, 2010 | 04:01 PM
hydrashocker's Avatar
hydrashocker
Go to a dealer and ask for a printed paper for the linkage showing how it is installed. You will most likely need a new clasp or something.
Old May 24, 2010 | 07:24 AM
tvogel's Avatar
tvogel
Thanks!
Old May 24, 2010 | 07:54 AM
Dans01Durango's Avatar
Dans01Durango
For a second I thought my work comp updated to a new OS, and running firefox!!! Then I realized it was hydra's screen shot...
