Door chime won't stop!
Old Jun 1, 2010 | 11:12 AM
DanHorne83's Avatar
DanHorne83
In response to shrpshtr's quote...I think there's an app for that...ha ha...love the quote...too bad you just can't hit the "end" button.
Old Jun 1, 2010 | 11:24 AM
DanHorne83's Avatar
DanHorne83
I don't know if it's related, but sometimes when my door is locked and when I go to unlock it, the horn blasts 3 times...I found an owner's manual for a Silencer Alarm system and in the book it says that if you unlock the car and it does that then someone has tampered with the security system (short would tamper right?). I also found a vallet switch (not attached to anything) and looked in the book for where it plugs in to see if I could cut off the system if it is in fact installed and could not find where it plugs in. I'm thinking there may be a short in the securtiy system, but wouldn't that have been discovered pulling fuses? Also, I checked to see if there was any other wires running to the battery's positive terminal, but the only thing running to it is the single factory cable, nothing spliced in...as far as I could see. You guys have been an amazing source of knowledge and help and I'm very grateful for that...I've gone into some automotive chats and they weren't the least bit helpful, just made "momma" jokes and I didn't have time for the infantile behaviors that is AOL. Thank you for your contributing help so far.
Old Jun 1, 2010 | 03:06 PM
DanHorne83's Avatar
DanHorne83
Default I found it!
I took the left panel off from right inside the drivers side door under the dash and found a unit that said Daimler Chrysler and Motorola, I unplugged some off the connections going into it and found the one causing the chime...now with it unplugged, I cranked the car and I'm getting a "Service 4X4" light on the dash. Hope this helps for a possible diagnosis.
Old Jun 1, 2010 | 03:31 PM
hydrashocker's Avatar
hydrashocker
That is the CTM!!!!!
Well thanks!
Very well could be an issue that was in the aftermarket alarm system that was put in your truck. If you have a "vallet switch" then you had an aftermarket at one time. Those aftermarket systems really mess things up in the Durangos. Look in the dash fuse panel to see if you have a splice off or anywhere else?
DanHorne83's Avatar
DanHorne83
Also, the connection I unplugged is linked to the power door locks.
Old Jun 1, 2010 | 04:09 PM
schusterjo's Avatar
schusterjo
Glad ya was able to get it...
Old Jun 1, 2010 | 05:11 PM
DanHorne83's Avatar
DanHorne83
This is the CTM...it appears to have crude cuts and what looks like melting of some sort...
http://s1045.photobucket.com/albums/...6-01163352.jpg
This is what I found when I removed the panel around my steering column...it has a wire that is spliced but only to it's self, I guess they removed the alarm and just patched the gap...
http://s1045.photobucket.com/albums/...6-01162834.jpg
there is also the remanants of a ground wire I'm guessing to the left of the picture
Sorry for just pasting links, I couldn't get the image uploader to accept the link without showing "This image has been removed or deleted"
Old Jun 1, 2010 | 10:46 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
that is definitely not normal (or good), and it does sound like you had an aftermarket alarm in the truck at some point, and it also sounds like it was very sloppily installed, hence causing problems, which is PROBABLY why it was removed
Old Jun 2, 2010 | 08:00 AM
DanHorne83's Avatar
DanHorne83
So do I need a new CTM or what's my next step?
Old Jun 2, 2010 | 03:38 PM
hydrashocker
I would first look for any and all record of the aftermarket alarm system and see if they left any pieces in and check wiring.
Next do a alarm reset. https://dodgeforum.com/forum/1st-gen...going-off.html
After that maybe a CTM.
