318 to 360 swap. What do i deed and how do i do it
Old Jun 6, 2010 | 06:24 PM
Jordan91ulbrich's Avatar
Jordan91ulbrich
Default 318 to 360 swap. What do i deed and how do i do it
I have a 1998 Dodge Durango and it has a 5.2 in it and i want to put a 5.9 in it how do i go about doing this, what will i need, and how big of a project am i looking at
Old Jun 6, 2010 | 06:34 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the engine, the pcm (computer) and possibly the flywheel (i think) that goes btwn the engine and transmission
the blocks are the same, and the wiring harnesses are the same so you should be pretty good to go
Old Jun 7, 2010 | 12:18 AM
Jordan91ulbrich
oh ok ill look into it, and i know were the fly wheel is lol
Old Jun 7, 2010 | 07:47 AM
shrpshtr325
THE ULTI-MOD
lol im not sure if flywheel is the correct term, it might be flexplate, but i couldnt think of it last night.
Old Jun 7, 2010 | 05:16 PM
schusterjo's Avatar
schusterjo
Well the 5.2L pcm will work with the 5.9.. u always can upgrade later if needed.. There was another post on this exact same subject an i had said the 5.2L pcm would work, well some said no it would not, the guy posted back he did the engine swap an had no issues using the 5.2L pcm.. the 5.2 is internal balanced the 5.9 is external balanced.. you will need the harmonic balancer that was on the 5.9.. other then that all else should plug right in.
Old Jun 7, 2010 | 06:35 PM
shrpshtr325
THE ULTI-MOD
hmmm i heard that the 5.2 pcm would work, but that it wouldnt be able to put out the same power as the 5.9 pcm would on a 5.9l engine, so i suggested for the full benefit (probalby just a different program on the chip) get the computer
Old Jun 7, 2010 | 10:01 PM
hydrashocker's Avatar
hydrashocker
That is correct. It will work but not give him all the available power until he re-flashes the PCM.
