Bad Speaker
Old Jun 24, 2010 | 05:24 AM
MAGIC84's Avatar
MAGIC84
Hydra, you have missed more than a few notes my friend............LOL!!!!!
However not in this case......
I used the Wiring adapters from BestBuy and can say the same thing. You remove the speakers, remove the factory harness, insert the B/B adapter and plug pos-pos and neg-neg to the new speaker and your done. Ops check speakers reinstall door panel and thats it. There isnt a unknown part of the speaker.........only two terminals.....Positive and negative.....so simple a light to moderately inebriated RAM V10 Q/C owner from Utah could do it.
Old Jun 24, 2010 | 07:52 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by MAGIC84
.....so simple a light to moderately inebriated RAM V10 Q/C owner from Utah could do it......
when is hydra less than heavily inebriated???
Old Jun 24, 2010 | 08:41 AM
MAGIC84's Avatar
MAGIC84
I was trying to give him the benefit of the doubt for a worknight.
Old Jun 24, 2010 | 10:02 AM
Turbozcs2003's Avatar
Turbozcs2003
What the heck do you need a best buy special adapter harness for, why not just cut the harnes off the old OEM infinity and solder it onto the new speaeker?
WHat is the part # of this Best Buy adapter???
Old Jun 24, 2010 | 10:33 AM
MAGIC84's Avatar
MAGIC84
Not sure what part # is but I think for the money $12.86 for set of 2, I think it is worth it. I am sure solder/heat shrink/tools would come close to that plus you have the manual labor involved. The BestBuy is literally plug and play and all set to go right from package. There is only two wires involved and as I stated before a moderately inebriated RAM V10 Q/C owner from Utah could do it with one Jack and Coke tied behind his back.
Old Jun 24, 2010 | 12:26 PM
hydrashocker's Avatar
hydrashocker
Ouch!
That's ok, I was pretty sloshed last night.......LOL......But it didn't make sense so I figured it should be a lil more explained is all.
Old Jun 24, 2010 | 01:46 PM
shrpshtr325
THE ULTI-MOD
hell i got all those tools already, but being an engineering student i dont have a choice but to have them (btw a good set of soldering tools will cost you around $20 for a low power iron, closer to $40 for a high power one, and then the heat shrink wrap is a freaking rip off, i prefer liquid electrical tape )
Old Jun 24, 2010 | 10:58 PM
MAGIC84's Avatar
MAGIC84
I can't speak for your budget or technical experience level but IMHO the two sets of Best Buy wiring adapters at about $13 per set, are quick, readily available and literally should take no more than about 30 seconds to install.
The hardest part of this r/r is the trim panel but even that is not so bad. Take your time and the brass trim ring that is in the factory panel will not be needed again.
If in doubt after each speaker is replaced ops check. Run fade/bal all the way to the speaker that you are replacing, then once all four speakers are installed then do one final ops check.....Start at Center, then LF....RF....RR....RF.....Then back to center and you should be done..... Also, like I said....try the front speakers first.......if those work out, then go from there. Whether you use the Infinity or some other brand the technique should be pretty much the same ony the wiring adapters might change to meet your specific speakers.
Old Jun 25, 2010 | 02:13 PM
MongoDV8's Avatar
MongoDV8
Or go with Crutchfield.com they give you any spacers, adapters and wire adapters you need. Just stay away from any " shallow mount " speakers. They sound like crap.
