Transmission Chatter 30 MPH
Old Jun 27, 2010 | 08:45 AM
fifth wheel's Avatar
fifth wheel
Default Transmission Chatter 30 MPH
2000 Durango 4.7, automatic, 4X4. Feb, I had the truck sreviced at dealership trans fluid and drive line $1500.00. Within 48 hours of service when I selected drive it was hard going in to gear almost like trying to shift a standard with out the clutch. Happened only once. Mid March I drove to Florida and back to Buf NY no problems. Jun 26, upon pulling away from traffic signal I heard a chattering noise around 30 MPH. It stopped after a few seconds. I was going under a overpass so I blew it off to the truck going over head. That evening I heard it again. I was driving through a park 15-20 MPH, as I departed the park I slowly accelerated and around 30 MPH I heard it again, a few seconds it stopped, no other vehicles around so I know its my truck. I don't know for sure if it is transmission. Any one have any ideas what may be going on?
Old Jun 27, 2010 | 03:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
I found two TSB here is the first on.
Form TSB-003 Rev. 1.08 February 3, 2000
NUMBER: 03-06-00
GROUP: Axle
DATE: August 11, 2000
SUBJECT:
Sound Coming From The Front Axle During Acceleration At Vehicle Speeds between 5 to
30 MPH.
OVERVIEW:
This bulletin involves the replacement of the right side front axle bearing.
MODELS:
2000 (AN) Dakota
2000 (DN) Durango
NOTE: THIS BULLETIN APPLIES TO FOUR WHEEL DRIVE VEHICLES.
SYMPTOM/CONDITION:
The customer may experience a repetitive whoop – whoop like sound coming from the
front axle. There have been some complaints of a scrapping, grinding, or chirping like
sound that has been attributed to this condition. The sound will increase in frequency with
vehicle speed. This sound will occur only during vehicle acceleration and normally
between the vehicle speeds of 8 to 48 kph (5 to 30 MPH). The sound may be more
noticeable once the front axle has reached normal operating temperature.
DIAGNOSIS:
Slowly accelerate the vehicle from a stop. If the sound is present during acceleration, then
perform the Repair Procedure.
PARTS REQUIRED:
1 52111167AA Bearing, Front axle (C205) right side
1 52069706 Seal, axle shaft seal right side
1(AR) 05010320AA Fluid, axle
EQUIPMENT REQUIRED:
8420 Puller Adapter
C-3752 Slide Hammer
C-4660-A Bearing Removal Tool
5063 Installer
C-4171 Handle
R2. Once the axle has been reassembled, verify the correct front axle fluid level..
Old Jun 27, 2010 | 03:37 PM
master tech
NO: 02-02-00 Rev. A
SUBJECT: 40-48 KPH (25-30 MPH) Driveline Drone/Vibration
DATE: July 7, 2000
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 02-02-00, DATED APRIL 21, 2000, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE REVISED PART NUMBERS.
OVERVIEW:
This bulletin involves installing revised rear leaf springs.
NOTE: THIS BULLETIN APPLIES TO 4X4 VEHICLES BUILT BEFORE NOVEMBER 22, 1999 (MDH 1122XX) AND 4X2 VEHICLES BUILT BEFORE NOVEMBER 29, 1999 (MDH 1129XX).
SYMPTOM/CONDITION:
Customers may complain that while driving on a smooth road, they hear a drone/vibration that occurs between 40-48 kph (25-30 mph). In some cases, the drone/vibration resonance may cause the instrument panel to buzz.
DIAGNOSIS:
Drive the vehicle on a smooth paved road. Accelerate the vehicle to 56 kph (35 mph). If the driveline drone/vibration starts to occur at/or close to 40 kph (25 mph) and is gone by the time 48 kph (30 mph) is reached, perform the Repair Procedure. If the drone/vibration occurs before 40 kph (25 mph) or occurs after 48 kph (30 mph), further diagnosis is required.
NOTE: IF CONDITIONS DO NOT ALLOW THE ROAD TEST TO BE PERFORMED PROPERLY, PERFORM THE REPAIR PROCEDURE IF THE CUSTOMER’S DESCRIPTION OF THE CONCERN MATCHES THE DESCRIPTION IDENTIFIED IN SYMPTOM/CONDITION.
PARTS REQUIRED:
Qty Part No. Description
AR (2) **52106831AG** Spring, Rear Leaf, 4X2 Vehicles
AR (2) **52106830AG** Spring, Rear Leaf, 4X4 Vehicles
4 **52039305** U-Bolt
8 06502698 Nut, U-Bolt
REPAIR PROCEDURE:
Remove both rear leaf spring assemblies and replace them with new springs (see Parts Required section).
