water on passenger side floor
Old Jul 2, 2010 | 10:49 AM
Chuck D's Avatar
Chuck D
Default water on passenger side floor
I'm shore it's coming from A/C drain back up but can't find where the drain tube comes out of cab. How do you clean out drain? Thanks Chuck
Old Jul 2, 2010 | 11:02 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the drain should come out through the firewall on the passenger side of the truck, you SHOULD be able to clean it out with a piece of wire coat hanger, but i know alot of people had no clog and the problem was caused by air pushing the water back into the hose as you drive, putting a 90 degree elbow on the end to point it down will solve the problem.
Old Jul 2, 2010 | 12:21 PM
Chuck D's Avatar
Chuck D
Thanks for the reply, I looked where you said and can't find it. My friends dodge is a 2003 Durango that has the leak,I am just helping him, is there something that might be covering it? I saw pic from another post of where it is located but the pic looks like it/s from an older Durango because it's to easy to locate in the pic virsis what i'm looking at in the 2003.
Old Jul 2, 2010 | 12:29 PM
shrpshtr325
THE ULTI-MOD
when i get home tonight ill take a picture of mine (2002) for you, but it SHOULD be very easy to find, i will see what i can get for you
Old Jul 2, 2010 | 01:28 PM
Chuck D's Avatar
Chuck D
Thanks alot because i'm just not seeing it.
Old Jul 4, 2010 | 12:02 AM
hydrashocker's Avatar
hydrashocker
Cause I think he forgot........LOL
Old Jul 4, 2010 | 12:11 AM
raggmopp's Avatar
raggmopp
Default passenger side leak
also check the auxiliary water pump, located by passenger side fire wall towards back
this pump has a history of failing and tell tale sign is water leak right behind passenger front tire
assuming hoses are good, 20 min fix
Old Jul 4, 2010 | 08:49 AM
shrpshtr325
THE ULTI-MOD
ahh ****, you caught me hydra, too much booze the last couple of days, ill get on it
Old Jul 4, 2010 | 02:59 PM
45AutoPete's Avatar
45AutoPete
Most people do not know that Durango's with rear A/C-Heat have that auxiliary pump for the rear. But the OP is looking for the drain for his front A/C unit, he does not have a leak or is leaking coolant.
Old Jul 6, 2010 | 11:24 AM
Chuck D's Avatar
Chuck D
Default Found drain for A/C
Well I found the drain and no you can't see it because it is covered by a piece of aluminum behind the exhaust header pipe.
Thanks for your help. Charlie
