Charcoal canister hose replacement
Old Nov 17, 2012 | 05:45 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
disconnecting the battery should NOT erase the key fob programming unless there is something wrong w/ the CTM (the receiver unit for the fob)
Old Nov 18, 2012 | 10:03 AM
bmac423's Avatar
bmac423
Thanks again shrpshtr325. I did the manual reset and the check engine light went away. Does this mean the problem's likely fixed, or will it take a while to know for sure?
Old Nov 18, 2012 | 04:37 PM
shrpshtr325
THE ULTI-MOD
it will take a little while to be sure, if it stays off for a couple weeks id venture a guess that the issue is solved since it takes a few cold-hot-cold cycles to set off the code
Old Jun 10, 2014 | 01:36 PM
rcope96's Avatar
rcope96
Default hoses
Where did you you buy the hoses from and then did you just cut it to size
Old Jun 10, 2014 | 09:16 PM
shrpshtr325
THE ULTI-MOD
any auto parts store should have them, and yes i just cut them to size myself
keep in mind that there is now a kit available w/ the correct hoses so you no longer have to build your own set. (i dont have the part # unfortunately, but i know that a couple guys on here have used them)
Old Jun 11, 2014 | 07:21 AM
SmokinJoe02's Avatar
SmokinJoe02
Don't buy those kits. I went through 4 kits from RockAuto and they split after time since they weren't fuel rated. Just go buy fuel rated hoses and clamps.
SJ02
Old May 31, 2016 | 10:45 AM
Chris Walker's Avatar
Chris Walker
Default Agreed.
So SmokinJoe02 said "don't buy those kits they are garbage"
Yup... sure as hell are... mine often don't last a month.
This is the kit he is talking about
Amazon.com: Dorman 46020 HELP! Evaporising Hose Kit: Automotive Amazon.com: Dorman 46020 HELP! Evaporising Hose Kit: Automotive
I have bought it from rock auto KOI and some other local chain... always the same "HELP!" branded Dorman **** hoses.
Someone in the comments down there on the amazon listing said
"This replaces Mopar part# 5166499AA."
Which is really handy... because google gave me this...
http://www.tascaparts.com/oe-mopar/5166499aa
And IMHO it looks right to me... so I just ordered them from that Tasca place... it says "Genuine OEM Mopar" I'm hoping I get more life out of these... my first set of hoses lasted me from 2003 to 2015... 12 YEARS... the Dorman junk I consider myself lucky to get 12 DAYS lol.
I know.. first time poster with links to buy stuff is generally scam stuff... but I was looking here for the part numbers and kept this page open for when I found them because I was not going to buy Dorman again and I figured you all would be happy to have the info when I sorted it out.
Have a good one,
Chris
Old Jan 19, 2018 | 10:25 PM
timjor's Avatar
timjor
Just a quick question - could replacing these hoses also help with the P1495 Leak Detection Pump Solenoid error code?
