removing underhood heat/ muffler
Old Jul 14, 2010 | 04:43 AM
LuxuryDodge's Avatar
LuxuryDodge
Default removing underhood heat/ muffler
ok to remove underhood heat i have removed the rear rubber seal, splash guard, and rubber between grill and headlights. is there anything else i could do that isnt tacky or dangerous? also my durangos underbody is basically rust free but if i wanted to install JUST a muffler how do i get the old one off? thanks
Old Jul 14, 2010 | 08:18 AM
Fox Fader's Avatar
Fox Fader
All those are there to keep water away.
Low pressure is built up under the truck when its moving forcing the hot air out.
If you want the hot air out after you have stopped and shut down. Open the hood. I babied my Mazda this way.
Old Jul 14, 2010 | 01:02 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
think you meant high pressure under the hood (fan is pulling MORE air into engine bay, movement pushes more air into engine bay, more air in constant volume = high pressure), but yes that does plenty well enough to push the heat out while moving
Old Jul 14, 2010 | 01:12 PM
Fox Fader's Avatar
Fox Fader
Nope, it's low pressure, but I won't argue.
Old Jul 14, 2010 | 01:19 PM
shrpshtr325
THE ULTI-MOD
low pressure under the hood would be pulling fresh air in from outside the car(higher pressure) that air IS cooler, no doubt about it, but if you look at it, the air is being forced in at the speed the car is moving (approximately) which will raise the pressure under the hood in relation to the atmospheric pressure outside the vehicle, this will force the hot air out by the cold air which is being pushed in
Old Jul 14, 2010 | 01:23 PM
Fox Fader's Avatar
Fox Fader
The low pressure is under the truck, not under the hood. You'll figure it out.
Old Jul 14, 2010 | 09:33 PM
45AutoPete's Avatar
45AutoPete
Best way to get rid of heat under the hood is get a 2" cowl hood. Not only that, they look cool too!!
Old Jul 14, 2010 | 09:38 PM
45AutoPete's Avatar
45AutoPete
As high as the Durango's sit, there is minimal low pressure under the vehicle versus a lower to the ground car. The lower to the ground, the more low pressure.
Old Jul 14, 2010 | 10:07 PM
LuxuryDodge
very true does anyone know if they make a hood like the ls1 SS camaro hood's? it would also be kinda neat to cut out the grooves in the hood so there open.
Old Jul 14, 2010 | 10:12 PM
LuxuryDodge
do you happen to know if anyone on here has a 1st gen durango with the rear stock height but front lowered a bit to give it a muscle car stance?
