ABS problem?
Old Jul 16, 2010 | 12:42 PM
ela's Avatar
ela
Question ABS problem?
This problem has been going on for quite a while, but finally I figured I better fix it.
When I am driving, even at slow speeds, and I press the brakes at medium pressure the ABS kick in. I know that if I press the brakes hard they are supposed to kick in, but if I press them even at a slow speed they kick in. It almost feels like it is too sensitive. When this occures, I dont feel the ABS doing the bumpy feeling in the brake pedal like in my other car, but it just makes that weird sound of the ABS. I am hoping it may be just a sensor or something, but does anyone have any ideas?
Thanks
FYI 1999 DODGE DURANGO 4WD 5.9 V8
Old Jul 16, 2010 | 04:40 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
try the rear wheel speed sensor (on the top of the rear differential), it controls the rear wheel abs.
also, it sounds like you only have rear wheel abs, double check your VIN at a dodge dealership (should be free) to make sure. if you have 4 wheel abs then something else is wrong with the system too
Old Jul 16, 2010 | 11:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
ela
Welcome to DF
First thing i would do,is pull the codes from the ABS module and post.Could be a bad sensor, but could be an open circuit.
Old Jul 16, 2010 | 11:54 PM
hydrashocker's Avatar
hydrashocker
Could also be the ABS module going out.
When was the last time you changed your brake fluid?
Old Jul 17, 2010 | 12:57 AM
ela's Avatar
ela
Forgive my ignorance but how do i pull the codes for the module?
Originally Posted by master tech
ela
Welcome to DF
Old Jul 17, 2010 | 08:00 AM
shrpshtr325
THE ULTI-MOD
you need a scan tool in order to pull codes for the abs module, most shops should be able to do it, im not sure if autozone ect would have the stuff to do it for you
Old Jul 20, 2010 | 11:02 PM
ela's Avatar
ela
wouldnt the check engine light or abs light be on if it was going to pull a code? If so, is it possible to pull the codes any other way, like the on off, on off, on off trick?
Also is when the abs kicks in and you can here the buzz sound like a pump, does the brake pedal vibrate like on most cars, or are these trucks different?
Old Jul 20, 2010 | 11:10 PM
master tech
Cylcing the key will only give stored engine codes, You will need a scanner to scan the ABS module or any other modules.Once you have the codes,then post them. This way all of us can help you.
Old Jul 20, 2010 | 11:14 PM
ela's Avatar
ela
do i just need an obd-II code reader?
They want 50 bucks to scan it at the shop, but the sell the for 50 bucks at harbor freight
http://www.harborfreight.com/can-obd...enu-98568.html
or do i need a different type of scan tool?
Old Jul 20, 2010 | 11:27 PM
master tech
Do you have an autozone in your area or do you know a tech that works in a dealer? I use the DRB3 scanner. This is what mopar use's others,starscan,starmobile,DRB2,DART Tool,and witech.
