Grinding, groaning, creeking...
Old 07-22-2010, 10:56 PM
samnbensdad's Avatar
samnbensdad
samnbensdad is offline
Default Grinding, groaning, creeking...
02 Durango, 5.9L, AWD, 150k...
How do I determine if I have bad wheel bearings vs. cv-joints vs. ball joints vs. etc...?
My Durango makes a grinding or groaning noise when I turn either direction at low speeds... pulling into parking spaces or making u-turns are rediculous. I also get a grinding noise over bumps... pulling into my uphill driveway or speedbumps. Also, not sure if its related but, occasionally I get a grind/vibration for about 1-2 seconds between 35-50 mph.
I have tried the usual testing for ball joints & wheel bearing by manually rock side-to-side or back and forth with the tires jacked up. They don't seem to move.
These issues have gone on for over a year now. I can't find a mechanic that is smart enought to figure it out. I was told by a dealer mechanic that he thought it was ball joints, but they were replace with the recall. Also, I have a receipt showing that Firestone replace the rack & pinion a few years ago.
Any thoughts before I replace my entire front end piece by piece?
Old 07-22-2010, 10:58 PM
jake7's Avatar
jake7
jake7 is offline
I'm interested in what people say...I also get some funky noises when turning at low speeds...nothing over speed bumps like you though etc
Old 07-22-2010, 11:20 PM
Frankenstein811's Avatar
Frankenstein811
Frankenstein811 is offline
Well, I can tell you from personal experience of both the same problem and the same exact truck, that you ain't gonna like it. The top 3 culprits that I found were bad and had to replace were.... 1. The CV Joints. 2. Hub assembly. 3. This was a pain in the tail.... the front propeller shaft (driveshaft).
Old 07-22-2010, 11:59 PM
samnbensdad
I just replaced the front propeller shaft. It started making a crazy noise a few months ago. It would have been much easier with a lift. I kept one wheel jacked up and the transfer case in neutral (emergency brake and wheel blocks of course). That made it much easier to spin the shaft to get to those bolts. I had my wife step on the brake when I needed to break or tighten the bolts. The tread lock tape still made it tough though. My next chore will be cv joints I guess.
Old 07-23-2010, 07:29 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
wheel hub is more likely in my experience, from what you are describing (especially the noise in turns)
Old 07-23-2010, 06:45 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Sounds like a wheel bearing.
Old 07-23-2010, 11:27 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Take it in to a tire shop for an alignment. When they can't because stuff is all whack, they will tell you want is wrong since they want to fix it for you.
IndyD
Old 07-24-2010, 12:36 AM
hydrashocker
+1 on that!
Even if you say no and I will do it myself, they will not charge you and will help you in figuring out the issue.
Quick Reply: Grinding, groaning, creeking...
