98 Durango Tranny line
Old Jul 23, 2010 | 06:04 PM
dctaz37's Avatar
dctaz37
Default 98 Durango Tranny line
One of my lines sprung a leak. It is on the drivers site furthest back and goes to the top of the rad some place. It connects to a rubber line at the bottom of the rad then switches back to steel near the top of the tranny but it is crimped while the other line has fittings that can be removed. It looks like a big job just to get at the rad connection. My question is: Can I cut the bad piece out and section in a new piece with flares and connectors?
Old Jul 23, 2010 | 06:26 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
pictures would help us to see what you are talking about bc i dont quite follow the words
remember a picture is worth a thousand words when explaining something like this
Old Jul 23, 2010 | 07:19 PM
dctaz37's Avatar
dctaz37
I don't have the line off because I'm trying to avoid it if possible. I think I attached a photo.
Old Jul 23, 2010 | 11:07 PM
shrpshtr325
THE ULTI-MOD
i would say that you COULD make the repair in the way that you described, but i would NOT recommend it, this is a transmission cooler line and if i were you i wouldnt want to take the chance that the repair would fail while i was driving down the road
IMO replace the entire unit, hard line and all
Old Jul 24, 2010 | 12:19 AM
hydrashocker's Avatar
hydrashocker
The dealership sells the lines as a whole unit! The line in question is a return line to the transmission. This connection leaks if not done right so be VERY careful. You can buy these set of lines at the dealer for about $50 bucks. Replace and post back.
Old Jul 24, 2010 | 12:28 AM
master tech's Avatar
master tech
Site Moderator & Tech
If you end up replacing the lines,You will need to drop the front diff to replace the lines.
