Body Control Module (alarm troubles)
Old Jul 27, 2010 | 04:01 PM
clap's Avatar
clap
Default Body Control Module (alarm troubles)
I am having alarm troubles in my 01 Durango and the dealer says it sounds like the body control module (bcm) .They told me it was in the gauge cluster on the dash and that I would have to replace the whole gauge cluster at $600 plus dollars. When you unlock the door with the remote or the key and then open the door the alarm goes off, it will shut off when you put the key in the ing. and start it, but this does not always shut it off. Can anybody help me? What about the CTM ? My son put his boss"s Snap On Computer scan tool on it and it comes up #1 ROM Check sum failed and #2 Door ajar input.
Thanks
Old Jul 27, 2010 | 08:01 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i have never heard of a bcm, but it sounds to me like the CTM is acting up (even without the codes from your sons tool)
that would be my starting point especially with the rom code coming out
just remember to take your keys with you to the dealer so that they can program the new ctm with your key fobs.
Old Jul 27, 2010 | 11:13 PM
hydrashocker's Avatar
hydrashocker
Do a factory alarm reset first:
Originally Posted by hydrashocker
Put lock all the doors manually and close all doors with the drivers door shut lastly. Insert the key into the drivers side door and turn it like you are trying to lock it (counter clock). Now turn it all the way to the other side like you are trying to unlock the door (clock) and you will see the lock come up. Now turn the key to the middle position and remove key. Now open the door. DO NOT USE THE KEY FOB WHILE DOING THIS.
This is how to complete a full reset of the alarm.
Hope it fixes the issue!
Old Jul 28, 2010 | 12:51 AM
IndyDurango's Avatar
IndyDurango
BCM **is** the CTM per 1998 specs. His 2001 is (properly) called a CTM.
IIRC, BCM is also a FORD term. Their combo of BCM, GEM and CPU do what our PCM and CTM do together.
IndyD
Old Jul 28, 2010 | 10:31 PM
hydrashocker
There's just too many abbreviations there Indy!
