Engine compatibility
Old Jul 30, 2010 | 09:37 PM
txswingster's Avatar
txswingster
Default Engine compatibility
I've got an '01 Durango with a blown 32 tooth 4.7. Could this be original, or has it been replaced? Will an '06 32 tooth 4.7 fit?
Old Jul 31, 2010 | 02:02 AM
IndyDurango's Avatar
IndyDurango
32 tooth 4.7 to 32 tooth 4.7 should be fine. With that said, any from a 01-03 will certainly match and be a safer bet.
IndyD
Old Jul 31, 2010 | 02:09 PM
hydrashocker's Avatar
hydrashocker
They should fit but I would look for something in 01-03 first. They changed the motor to create more power and thus they changed parameters so I'm not sure 2004+ will work, but it would be fun to find out.
2000-2003<-----2000-2004 - 4.7 L (287 cu in) PowerTech V8, 230 hp (170 kW)
2004+<----- Its new 4.7 liter V8 produces 302 hp (225 kW) and 329 lb·ft (446 N·m) of torque.
Old Aug 1, 2010 | 05:44 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if it has the same tone ring on the engine it SHOULD swap out just fine, but i would personally try to find one from the same year
you messed it up again
2004(or 05)-2007 4.7L = 230 hp
4.7L H.O.(high output) = 265(iirc)hp
2008 (the "NEW") 4.7L = 310 HP (as per the build sheet in my dads 09 dakota)
http://www.allpar.com/mopar/47.html
http://en.wikipedia.org/wiki/Chrysler_PowerTech_engine
Old Aug 3, 2010 | 01:02 PM
hydrashocker
I really need to imput where I got that info cause it was a copy and paste. Check this out! http://en.wikipedia.org/wiki/Dodge_Durango
Old Aug 3, 2010 | 01:19 PM
IndyDurango
You can't trust the wiki-sources. It also says "HS" was instrumental in co-engineering the new 4.7l
Old Aug 3, 2010 | 01:53 PM
Tony67Cuda's Avatar
Tony67Cuda
Default Engine swap
I also have an 01 durango with a bad 4.7l i bought a 06 4.7l crate motor from a swamp meet and not knowing any beter swamped the moter out and everything bolted up then i found out 01 and some 02's had 16 tooth ring tones and the rest had 32 tooth ring tone. I read all the post and found out the easiest way is to swap out the ring tones but thats only from the 1st gen to the 2nd gen. I still have not herd that an 06 motor will work in an 01 durango is their anybody out there that knows this will work for sure. Also would it be easier to swap out the wiring harness to the newer pcm or is their anyone that can reprogram these to get this engine to run in my truck.
Old Aug 3, 2010 | 03:49 PM
hydrashocker
According to Sharps it will work.
The 2000 and some 2001's have a 16 tooth while the rest 2001 up have 32 tooth, not just gen 1 and gen 2 Tony.
As for your other question. You should replace the tone ring from your old engine which is a 16 tooth to the new motor. Don't mess with anything else because the PCM also talks to many other modules. YOu will have to seporate the motor and trans.
Old Aug 3, 2010 | 04:46 PM
shrpshtr325
THE ULTI-MOD
yea i vaguely remember reading about someone making it work by swapping out the tone ring, but ill be damnd i cannot find the link now
and hydra from your link
-1998–2000 — 5.2 L (318 cu in) Magnum V8, 230 hp (172 kW)
-1999–2000 — 3.9 L (238 cu in) Magnum V6, 175 hp (130 kW)
-1998–2003 — 5.9 L (360 cu in) Magnum V8, 245 hp (183 kW)
-2000–2003 — 5.9 L (360 cu in) Magnum V8, 250 hp (186 kW)
-2000–2003 — 4.7 L (287 cu in) PowerTech V8, 235 hp (175 kW)
-2004–2009 - 3.7 L (226 cu in) PowerTech V6, 210 hp (157 kW) at 5200 rpm and 235 lb·ft (319 N·m) at 4000 rpm
-2004–2007 - 4.7 L (287 cu in) PowerTech V8, 235 hp (175 kW) at 4500 rpm and 300 lb·ft (407 N·m) at 3600 rpm, co-engineered by HS
-2004–2009 - 5.7 L (345 cu in) Hemi V8, 335 hp (250 kW) at 5200 rpm and 370 lb·ft (502 N·m) at 4200 rpm (MDS equipped for 2006+ 5.7L engines for improved fuel mileage)
-2008–2009 - 4.7 L (287 cu in) PowerTech V8, 303 hp (226 kW) at 5,650 rpm and 330 lb·ft (447 N·m) at 3,950 rpm
and indy is correcty in his smart *** addition to the wiki, but put the 'co engineered by hs' on the later half of the 'old' 4.7
Old Aug 3, 2010 | 11:14 PM
IndyDurango
on purpose! Since it wasn't correct in the above. LOL.
I don't think HS has realized the wiki illustration yet. You can't trust it. Nice for reference but not always reliable for facts.
