Swapped the PCM now "no bus"
Old Aug 12, 2010 | 10:49 PM
TrueMetalGeek's Avatar
TrueMetalGeek
I just received and installed the rebuilt PCM.
Everything is working again.
I got the PCM shipped and everything for $194 from http://myworld.ebay.com/ebaymotors/a...rexchange-ace/
They send a return paid shipping label to send back your original one as a core. They give a waranty as long as you send in the core.
I'm sure they just fix whatever is broken. But this was the best price I have found because a used PCM from the junk yard is useless if not programmed to your VIN (emissions reasons).
Old Aug 13, 2010 | 07:31 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
great, glad you got it working again
Old Aug 13, 2010 | 11:45 AM
02 Durango_R/T's Avatar
02 Durango_R/T
Originally Posted by 02 Durango R/T
But in order to get the dealer to flash it, you would have to install the PCM and drive the truck to the dealer, right? How will you work around that?
Originally Posted by TrueMetalGeek
Are you talking about the rebuilt PCM I ordered?
No, I am referring to the one you proposed to get from the junk yard.
If I can get one from a salvage yard for $90 to $100 (like the other one I got) then it shoudn't cost any more than $100 to get the dealer to flash it.
How would you get it to the dealer for a flash (since I was told you can only flash it in the vehicle ...)?
Old Aug 13, 2010 | 08:30 PM
shrpshtr325
THE ULTI-MOD
this is clearly not true since you can order them online PRE-FLASHED to your trucks specifications
Old Aug 14, 2010 | 02:04 PM
02 Durango_R/T
Before this thread dies, one more question (now that the OP has solved his problem). If you buy a rebuilt PCM & get it flashed to your VIN, is there any way to get them to avoid the "death flash"?
I took my Grand Cherokee 5.9 in for some reason once (can't remember why, no longer have it) and the damn dealer gave it the death flash without my okay. I think it was already done to the D when I bought it, but I'd just as soon not have it. Possible?
Old Aug 14, 2010 | 04:05 PM
shrpshtr325
THE ULTI-MOD
i would think that you will get the most up to date (read: most recent)version, if you know the software version number you want, you could MAYBE get it (ask, worst they say is no) but chances are no
Old Aug 14, 2010 | 05:14 PM
02 Durango_R/T
s'what I figured . I want it back to how it was when it left the plant, before they neutered it.
I can dream.
Old Aug 14, 2010 | 10:13 PM
shrpshtr325
THE ULTI-MOD
check the PCM to see if it has the death flash, if it does it should have a sticker referencing that it was done.
Old Aug 18, 2010 | 08:38 PM
TrueMetalGeek
The place that I got it from http://stores.ebay.com/AUTO-COMPUTER-EXCHANGE
mentions that it comes with the "latest updates" so I would think perhaps it includes the "death flash".
I'm kinda thinking the "death flash" you all speak of is likely for the 5.2/5.9's.
I did have one problem with my PCM I received. Shortly after driving the check engine light came on. Getting P601. Internal memory issue. But everything else ok.
When I called they said they get that periodically when the battery is disconnected when for a while and when changing the PCM's.
They told me to leave the battery connected when I switch to the next one they will send me.
Also when I first got the PCM the idle was slightly high etc which was expected for a pcm without learning the vehicle.
It's been in there for several days now and today I noticed the idle is now around 600 or so where it is supposed to be and seems to be really smooth.
I don't notice any lack of power.
Oh yeah, when I had that temp pcm in there that don't match my vehicle and caused a "No buS" and no gauges, it also was ignoring the "torque managment" signal form the transmission module because it was shifting on full power. LOL!
My 2003 Dakota had the 4 plug PCM with the built in tranny control. I had to use a superchips to firm up the shifts (and that it sure did!) but with this I should be able to put a switch on the wire for the Torque Managment Request form the Transmission module like I did for ****s n giggles to my wife's Cirrus she used to have.
But, with 100,000 miles I'll likely leave it stock. I don't want to replace the tranny yet. :-/
Old Aug 18, 2010 | 08:50 PM
shrpshtr325
THE ULTI-MOD
yes the deathflash is a 5.2/5.9 deal, put in place as a 'band-aid' fix to predetonation/pinging
