Help!!! Trans cooler lines
Old 08-26-2010, 08:24 PM
gav'spurplez's Avatar
gav'spurplez
gav'spurplez is offline
Default Help!!! Trans cooler lines
I AM TRYING TO REPLACE THEM ON MY DAD'S 2000 durango and we can't remove the hoses from the fittings @ the radiator.
the one on the bottom is rusted to no end and the one on top just simply wont budge....
yes, i am using the blue clip tool.....no dice.
any tips / tricks ??? should these just be cut and pryed ( sp ? ) off ??
thanks in advance
Old 08-26-2010, 10:24 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
If it is rusted, cut it anyways. If you do it very close, you should have enough to make a new connection. If not, cut it back further and piece in a new section OR replace the entire line with one from the stealer.
IndyDurango
Old 08-26-2010, 11:11 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
I would just cut it off at the nut (seeing how you are replacing it anyways) and get it with a socket. Use penetrating oil on it and let it soak for a day.
Quick Reply: Help!!! Trans cooler lines
