02 durango electric prob
Old Sep 2, 2010 | 11:02 PM
cheese53073's Avatar
cheese53073
Default 02 durango electric prob
Symptoms are:
dome lights flicker
elecric door locks do not work
keyless entry works part time- once you get the doors to open/lock then the electric door locks will work
headlights do not work unless the key is on
I'm thinking ground wire somewhere but am at a loss of where to start.
Old Sep 3, 2010 | 12:54 AM
IndyDurango's Avatar
IndyDurango
Likely the Central Timing Module
$450 dealer install only. Take both key fobs with you for reprogramming
HTH,
IndyDurango
Old Sep 3, 2010 | 09:18 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
unfortunately, i agree with indy, sounds like the CTM dealer only bc it needs to be programmed to your trucks features and your key fobs, take em both with you
