Emission
Old Sep 14, 2010 | 03:47 AM
jldl's Avatar
jldl
Cool Emission
Had code p0456.....repaired 2 cracked lines at the Vapor canister. also replaced solenoid purge, after 120 mile engine lite comes back on, did a fog test all was good. rest computer engine lite came back on. have a 2003 4.7 sxt. thanx for any input....
Old Sep 14, 2010 | 08:37 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
what were the new codes???????
Old Sep 14, 2010 | 08:55 AM
jldl's Avatar
jldl
same code....PO456
Old Sep 14, 2010 | 09:41 AM
shrpshtr325
THE ULTI-MOD
you should also check the evap lines under the hood, (running past the battery area, look for a green cap) and the gas cap (yes it can cause the code if its bad)
Old Sep 14, 2010 | 10:23 AM
jldl's Avatar
jldl
I have replaced all the lines at the canister and the canister purge sensor and lines there as well. new gas cap, still getting PO456 code, one step further did a fog test with no leaks.......
Old Sep 14, 2010 | 10:27 AM
shrpshtr325
THE ULTI-MOD
did you try resetting the pcm?
Originally Posted by hydrashocker
To reset your engine codes:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery.
Start but do not hit the throttle. Idle for about 10/15 seconds then turn off.
Restart the truck and drive as usual. It will take at least 12 starts and 48 miles to fully retune the computer. Hard Codes leave a shaddow for 40 full cold starts.
Old Sep 14, 2010 | 10:44 AM
jldl's Avatar
jldl
i did when the code first came up about 2 months ago.....and did it again 3 weeks ago and 300 miles later lite came back on did a obdII test again same code PO456......thanx for your help
Old Sep 14, 2010 | 11:04 AM
hydrashocker's Avatar
hydrashocker
But did you replace the gas cap with a non-vented one?
Old Sep 14, 2010 | 11:14 AM
jldl's Avatar
jldl
yes i did.....non vented cap
Old Sep 15, 2010 | 12:23 PM
hydrashocker
Could be a bad line going to the purge valve from the caniser?
