01 Durango removing steering wheel
Hi all, Newbie here with a question. Some time back the airbag light came on, followed by the horn and cruise working on and off until they quit. After reading up on forums, it sounds like the clock spring. I have directions on how to replace it and ordered the part. Question is : Has anyone ever pulled a steering wheel? I have read you need a "steering wheel puller". Some that I've seen look very similar to the 3 arm gear puller I already have. It also changes over to a 2 arm tool. Will this work? Instructions for the clock spring replacement say I have to pull the wheel. Thanks much, Doug
IMO i would take it in bc of the airbag in the steering wheel, and if you screw that up it makes the project ALOT more expensive, but since you already ordered the part it sounds like you are not interested in that, so that being said, with the sensitivity of the area you are working in i would make sure to have the correct tools
I will take that under advisement. Thanks. I have the part ordered from the local dealer so I may rethink doing it myself. There have been things in the past that I have attempted and certainly wish that I hadn't tried on my own as it ended up costing me much more. Even ordering the part, the dealer asked me if I was "sure" that was the problem....Well...No, not 100% but maybe 90% sure. He told me that since it's an electrical part that it would not be returnable which I said I understood. Maybe I shouldn't chance it????
After disconnecting the battery you must wait 2 full minutes for the air bag to power fully power down as per the service manual. Personally I would do a PCM reset just to MAKE SURE it is powered down!
I have never pulled the steering wheel but master tech has posted the procegure but I cannot find it. I did find this for you though?
Torque Steering Wheel nut to 45 Ft lbs.
WARNING: THE AIRBAG SYSTEM IS A SENSITIVE,
COMPLEX ELECTRO-MECHANICAL UNIT. BEFORE
ATTEMPTING TO DIAGNOSE, REMOVE OR INSTALL
THE AIRBAG SYSTEM COMPONENTS YOU MUST
FIRST DISCONNECT AND ISOLATE THE BATTERY
NEGATIVE (GROUND) CABLE. THEN WAIT TWO
MINUTES FOR THE SYSTEM CAPACITOR TO DISCHARGE.
FAILURE TO DO SO COULD RESULT IN
ACCIDENTAL DEPLOYMENT OF THE AIRBAG AND
POSSIBLE PERSONAL INJURY. THE FASTENERS,
SCREWS, AND BOLTS, ORIGINALLY USED FOR
THE AIRBAG COMPONENTS, HAVE SPECIAL COATINGS
AND ARE SPECIFICALLY DESIGNED FOR THE
AIRBAG SYSTEM. THEY MUST NEVER BE
REPLACED WITH ANY SUBSTITUTES. ANYTIME A
NEW FASTENER IS NEEDED, REPLACE WITH THE
CORRECT FASTENERS PROVIDED IN THE SERVICE
PACKAGE OR FASTENERS LISTED IN THE PARTS
BOOKS.COMPLEX ELECTRO-MECHANICAL UNIT. BEFORE
REMOVAL
(1) Position the front wheels straight ahead.
(2) Disconnect the negative (ground) cable from
the battery.
(3) Remove the airbag, (Refer to 8 - ELECTRICAL/
RESTRAINTS/DRIVER AIRBAG - REMOVAL).
(4) Remove the steering wheel with an appropriate
puller,(Refer to 19 - STEERING/COLUMN/STEERING
WHEEL - REMOVAL).
the battery.
WHEEL - REMOVAL).
CAUTION: Ensure the puller bolts are fully engaged
into the steering wheel and not into the clockspring,
before attempting to remove the wheel. Failure
to do so may damage the steering wheel.into the steering wheel and not into the clockspring,
STANDARD PROCEDURE - CLOCKSPRING
CENTERING
CENTERING
The clockspring is designed to wind and unwind
when the steering wheel is rotated, but is only
designed to rotate the same number of turns (about
five complete rotations) as the steering wheel can be
turned from stop to stop. Centering the clockspring
indexes the clockspring tape to other steering components
so that it can operate within its designed
travel limits. The rotor of a centered clockspring can
be rotated two and one-half turns in either direction
from the centered position, without damaging the
clockspring tape.
However, if the clockspring is removed for service
or if the steering column is disconnected from the
steering gear, the clockspring tape can change position
relative to the other steering components. The
clockspring must then be re-centered following completion
of such service or the clockspring tape may be
damaged. Service replacement clocksprings are
shipped pre-centered and with the auto-locking tabs
engaged (raised). These auto-locking tabs should not
be disengaged until the clockspring has been
installed on the steering column. If the auto-locking
tabs are disengaged before the clockspring is
installed on a steering column, the clockspring centering
procedure must be performed.
clockspring tape.
WARNING: DISABLE THE AIRBAG SYSTEM
BEFORE ATTEMPTING ANY STEERING WHEEL,
STEERING COLUMN, OR INSTRUMENT PANEL
COMPONENT DIAGNOSIS OR SERVICE. DISCONNECT
AND ISOLATE THE BATTERY NEGATIVE
(GROUND) CABLE, THEN WAIT TWO MINUTES FOR
THE AIRBAG SYSTEM CAPACITOR TO DISCHARGE
BEFORE PERFORMING FURTHER DIAGNOSIS OR
SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE
THE AIRBAG SYSTEM. FAILURE TO TAKE
THE PROPER PRECAUTIONS COULD RESULT IN
ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE
PERSONAL INJURY.
NOTE: Before starting this procedure, be certain to
turn the steering wheel until the front wheels are in
the straight-ahead position.
PERSONAL INJURY.
(1) Place the front wheels in the straight-ahead
position.
(2) Remove the clockspring from the steering column.
(Refer to 8 - ELECTRICAL/RESTRAINTS/
CLOCKSPRING - REMOVAL).
(3) Depress the two plastic clockspring auto-locking
tabs (Fig. 8).
(4) Keeping the auto-locking tabs depressed, rotate
the clockspring rotor clockwise to the end of its
travel.
position.
tabs (Fig. 8).
travel.
Do not apply excessive torque.
(5) From the end of the clockwise travel, rotate the
rotor about two and one-half turns counterclockwise,
then release the auto-locking tabs. The clockspring
pigtail wire for the horn switch should end up at the
top, and the pigtail wires for the airbag, optional
speed control switches, and optional remote radio
switches at the bottom. The clockspring is now centered.
(6) The front wheels should still be in the straightahead
position. Reinstall the clockspring onto the
steering column. (Refer to 8 - ELECTRICAL/RESTRAINTS/
CLOCKSPRING - INSTALLATION).
REMOVAL
The clockspring cannot be repaired. It must be
replaced if faulty or damaged, or if the driver airbag
has been deployed.
has been deployed.
Fig. 8 Clockspring Auto-Locking Tabs
1 - AIRBAG MODULE WIRE
2 - SPEED CONTROL WIRING
3 - HORN WIRE
4 - CLOCKSPRING ASSEMBLY
5 - AUTO-LOCKING TABS
3 - HORN WIRE
BR/BE
RESTRAINTS 8O - 11
CLOCKSPRING (Continued)
PERSONAL INJURY.
PERSONAL INJURY.
position.
(2) Remove the driver airbag from the steering
wheel. (Refer to 8 - ELECTRICAL/RESTRAINTS/
(3) If the vehicle is so equipped, disconnect the
clockspring pigtail wire connectors from the speed
control switches and the remote radio switches
located within the hub cavity of the steering wheel.
(4) Remove the nut that secures the steering wheel
armature to the steering column upper shaft, which
is located within the hub cavity of the steering wheel.
(5) Pull the steering wheel off of the steering column
upper shaft spline using a steering wheel puller
(Special Tool C-3428-B).
(6) Remove the steering column opening cover
from the instrument panel. (Refer to 23 - BODY/INSTRUMENT
PANEL/STEERING COLUMN OPENING
COVER - REMOVAL).
(7) If the vehicle is so equipped, unscrew the lever
from the tilt steering column adjuster mechanism
located on the left side of the column just below the
multi-function switch control stalk. Turn the lever
counterclockwise to unscrew it from the adjuster.
(8) From below the steering column, remove the
two outboard screws that secure the upper shroud to
the lower outer shroud (Fig. 9).
(9) Press carefully inward on each side of the outer
shrouds to release the snap features and remove the
upper outer shroud from the lower outer shroud.
(10) From below the steering column, remove the
one center screw that secures the lower outer shroud
to the steering column housing.
(11) Remove the lower outer shroud from the
steering column.
(12) From below the steering column, remove the
two screws that secure the lower inner shroud to the
steering column housing and the upper inner shroud.
(13) Press carefully inward on the gearshift lever
side of the inner shrouds to release the snap features
and remove the lower inner shroud from the steering
column.
(14) Disconnect the instrument panel wire harness
connector for the clockspring from the lower clockspring
connector receptacle.
(15) Disconnect the lower clockspring pigtail wire
connector from the instrument panel wire harness,
located on the instrument panel lower reinforcement
below the steering column.
(16) Carefully disengage the plastic latches of the
clockspring assembly from the steering column lock
housing and remove the clockspring from the column.
has been deployed.
(17) If the removed clockspring is to be reused,
secure the clockspring rotor to the clockspring case to
maintain clockspring centering until it is reinstalled
on the steering column. If clockspring centering is
not maintained, the clockspring must be centered
again before it is reinstalled. (Refer to 8 - ELECTRICAL/
RESTRAINTS/CLOCKSPRING - STANDARD
PROCEDURE - CLOCKSPRING CENTERING).
position.
COVER - REMOVAL).
steering column.
column.
has been deployed.
Fig. 9 Steering Column Shrouds Remove/Install -
Typical
Typical
1 - NUT
2 - TILT LEVER
3 - UPPER SHROUD
4 - LOWER SHROUD
5 - SCREWS
6 - CLOCK SPRING
7 - STEERING WHEEL
2 - TILT LEVER
3 - UPPER SHROUD
4 - LOWER SHROUD
5 - SCREWS
6 - CLOCK SPRING
7 - STEERING WHEEL
8O - 12 RESTRAINTS
BR/BE
INSTALLATION
has been deployed.
If the clockspring is not properly centered in relation
to the steering wheel, steering shaft and steering
gear, it may be damaged. (Refer to 8 -
ELECTRICAL/RESTRAINTS/CLOCKSPRING -
STANDARD PROCEDURE - CLOCKSPRING CENTERING).
shipped pre-centered and with a piece of tape covering
the engaged clockspring auto-locking tabs. This
tape should not be removed until the clockspring has
been installed on the steering column. If the tape is
removed before the clockspring is installed on a
steering column, the clockspring centering procedure
must be performed.
has been deployed.
must be performed.
PERSONAL INJURY.
that the front wheels are still in the straight-ahead
position.
PERSONAL INJURY.
position.
(1) Carefully slide the centered clockspring down
over the steering column upper shaft until the clockspring
latches engage the steering column lock housing
(Fig. 9).
(2) Reconnect the lower clockspring pigtail wire
connector to the instrument panel wire harness connector
located near the instrument panel lower reinforcement,
below the steering column. Be certain that
the pigtail wire locator clips are properly seated on
the outside of the wiring trough and that the connector
latches are fully engaged.
(3) Reconnect the instrument panel wire harness
connector for the clockspring to the lower clockspring
(4) Position the lower inner shroud onto the steering
column. Be certain to insert the gearshift lever
hider strip into the channel located on the inside surface
of the shroud.
(5) Align the locking tabs on the gearshift lever
side of the upper inner shroud with the receptacles
on the lower inner shroud and apply hand pressure
to snap them together.
(6) From below the steering column, install and
tighten the two screws that secure the lower inner
shroud to the steering column housing and the upper
inner shroud. Tighten the screws to 2 N·m (18 in.
lbs.).
(7) Position the lower outer shroud onto the steering
column. Be certain that the lower clockspring
pigtail wire is routed inside the shrouds.
(8) From below the steering column, install and
tighten the one center screw that secures the lower
outer shroud to the steering column housing. Tighten
the screw to 2 N·m (18 in. lbs.).
(9) Align the locking tabs on the upper outer
shroud with the receptacles on the lower outer
shroud and apply hand pressure to snap them
together.
(10) From below the steering column, install and
tighten the two outboard screws that secure the
lower outer shroud to the upper outer shroud.
Tighten the screws to 2 N·m (18 in. lbs.).
(11) If the vehicle is so equipped, reinstall the
lever into the tilt steering column adjuster on the left
side of the column. Turn the lever clockwise to screw
it into the adjuster.
(12) Reinstall the steering column opening cover
onto the instrument panel. (Refer to 23 - BODY/INSTRUMENT
COVER - INSTALLATION).
(13) Reinstall the steering wheel onto the steering
column upper shaft. Be certain to index the flats on
the hub of the steering wheel with the formations on
the inside of the clockspring hub. Pull the upper
clockspring pigtail wires through the upper and
lower holes between the steering wheel back trim
cover and the steering wheel armature.
(14) Install and tighten the steering wheel mounting
nut. Tighten the nut to 61 N·m (45 ft. lbs.). Be
certain not to pinch the pigtail wires between the
steering wheel and the nut.
(15) If the vehicle is so equipped, reconnect the
upper clockspring pigtail wire connectors to the
speed control switches and/or the remote radio
switches. Be certain that the upper clockspring pigtail
wires are routed between the steering wheel back
trim cover and the steering wheel armature.
(16) Reinstall the driver airbag onto the steering
DRIVER AIRBAG - INSTALLATION).over the steering column upper shaft until the clockspring
(Fig. 9).
of the shroud.
lbs.).
together.
Sheesh...Thanks Hydra....I think??? Sounds worser and worser all the time. Think I'll make an appointment with the dealer tomorrow......
Seriously...I do appreciate the input. Sounds too risky for me to tackle.
Like I said above, "Not for the faint of heart."
If you have it all off, do yourself a favor and have them replace the clockspring with a new one while at it. Should be absolutely ZERO in extra labor so don't let them pull the added labor BS on you.
IndyDurango.
IndyDurango.
