2000 Durango 4.7L crank no start
Old Sep 21, 2010 | 09:46 PM
gav'spurplez's Avatar
gav'spurplez
Default 2000 Durango 4.7L crank no start
hey guys,
i performed a search and read multiple threads, but i guess i'm still posting another one.
my dad was driving around today with no problems, when he went to leave for bowling this evening, the truck did not start.
all lights and accessories work, battery is not new but is not old. The truck cranks but doesnt start. i believe i hear the pump when the ignition is on. i swapped out the fuel pump relay with the fog light relay, same condition.....
my friend who is a chrysler tech thinks its the crank sensor. where is this sensor located on a 4.7 ? ( he hasnt returned my text yet )
any other options ?? the fuel pump was replaced about 5 years ago under warranty.... it had a delayed crank but it started.
Old Sep 22, 2010 | 01:43 AM
IndyDurango's Avatar
IndyDurango
sensor is a good place to look so you are on the right track. Nice job swapping the relays as your first place to troubleshoot. Trust your instincts... they seem fine..
IndyDurango
Old Sep 23, 2010 | 10:09 AM
gav'spurplez
so my buddy came over with the scanner, and what do you know ?
the damn truck started, BUT the CEL was on......
P0340, no cam signal @ PCM.....so we bought a cam and crank sensor...my dad should be working on these today....
Old Sep 23, 2010 | 04:40 PM
hydrashocker's Avatar
hydrashocker
Make sure you disconnect the battery BEFORE you install the parts (negative side).
I think the cam is on the passenger side front and crank on the back passenger side.
Old Sep 24, 2010 | 07:10 PM
gav'spurplez
yep, all set...............running and starting like a charm
Old Sep 24, 2010 | 09:17 PM
hydrashocker
Thanks for the feed back and glad you got it!
Old Sep 25, 2010 | 08:56 AM
gav'spurplez
thanks !!
i'm just glad it wasn't anything more serious or "labor intensive"
