turn signals/hazard lights blowing fuses!
Old Sep 26, 2010 | 04:06 PM
MyRedRango's Avatar
MyRedRango
Default turn signals/hazard lights blowing fuses!
I have a 99 Durango and never had problems with signals until recently. The blinkers just stopped. I replaced the fuse under the hood, but that only works for ONE BLINK, and then the fuse is blown again. I have replaced the flasher unit under the dash twice. This last time, I found a small rock in the right rear light assy, removed the rock, and flashers worked for about three whole weeks. Yesterday everything went out again.
I don't have a clue where to begin to look for a short in the wiring, but I don't know what else to look for.
Please help?
Old Sep 26, 2010 | 08:30 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
its a short somewhere, unplug all the blinker bulbs, and plug them in one by one, if it still blows with all the plugs/bulbs out then its something int he wiring, if it doesnt blow then its one of the bulb sockets, i would then start plugging them in one by one until i find which one blows it, there is your problem
Old Sep 26, 2010 | 11:52 PM
master tech's Avatar
master tech
Site Moderator & Tech
Has the truck been in an accident? If it has,i would start with the damage area. If it hasn't been hit,then i would take out the bulbs one at a time as shrpshtr had said.
Old Sep 27, 2010 | 09:50 AM
Dans01Durango's Avatar
Dans01Durango
You're just low on blinker and bulb fluid!
Old Sep 29, 2010 | 12:19 AM
IndyDurango's Avatar
IndyDurango
Yep! $8.99 a quart and available online here:
http://kalecoauto.com/index.php?main...&products_id=6
HTH,
IndyD
