tru lok lsd clutch pak rebuild
hey fellas im new to the site and was wondering if anyone can help me i just bought a 00' durango with a 9.25 rear i opened it up to do a fluid change and i found ppieces of the lsd clutches at the bottom of the case im replacing the clutch paks and i need to know if the smooth ring goes againist the side gear or the carrier thanxs for the help in advance
o(llll
The O is the gear, and the outer edge ( goes against the clutch packs llll.
Also it is called a Trac-Lok......
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
![Name: 100_3489.jpg
Size: 73.8 KB](https://dodgeforum.com/forum/attachments/1st-gen-durango/75878d1501358869-tru-lok-lsd-clutch-pak-rebuild-100_3489.jpg)
yea i figured i wasnt calling it what its called but i have one more stupid question once everything is put together are the spider gears supposed to rotate when i spin the axles or are they supposed to be stationary thanks for bearing with me its my first attempt at doing this and its driving me nuts lol
If you spin one side and if you can hold the other side from spinning then then the spiders will spin. Thing is this is going to be VERY hard to do with brand new clutch packs. Most likely both wheels will spin together the same direction. But if you try hard you can get one to spin and the other to stay put and you will see the spiders (side gears) turn opposite.
