Help I need some direction
Old Oct 9, 2010 | 03:12 PM
whodafn's Avatar
whodafn
Default Help I need some direction
I replaced the heater core in my 98 durango 5.9 l motor
I cannot find where the plug from the overdrive button on the gear selector shaft plugs into.can anyone assist
2nd item my cruse control does not work but fuses look ok,everthing according to the book is there and looks like it is proper connected.
can anyone give me hints on where to look next thanks alot .
Old Oct 9, 2010 | 07:35 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
on the 98s im not sure
but here is the entire factory service manual in numerous pdfs
http://www.mediafire.com/?53f6w4a6wme00
if you cant find your answer in there idk where else to tell you to look
Old Oct 11, 2010 | 06:00 PM
hydrashocker's Avatar
hydrashocker
It should connect to the PCM.
One side of the switch goes to OR/WT.
The other side is BK
It looks like it goes into a Joint Connector bar so look close.
