2000 durango won't start ! Please Help !
Old Oct 11, 2010 | 12:39 PM
buc2000's Avatar
buc2000
Default 2000 durango won't start ! Please Help !
Hello all. I have a 2000 durango 2wd 5.9 autotrans. I have no idea why I can not get to start. It turns over good . I have pulled a plug and have spark. also checked fuel at rails and have fuel. change cam sensor also. no codes present. can it be a bad coil even though I have spark at no 2 plug ? how can I tell ? Don't have money to burn . the cam sensor cost 50 bucks and that was not problem and I can't return. can someone please help and thank you very much in advance.
Old Oct 11, 2010 | 04:05 PM
SumAmerican's Avatar
SumAmerican
did you tinker with her before she stopped working?? or was it a out of the blue thing??
Old Oct 11, 2010 | 04:58 PM
buc2000's Avatar
buc2000
Nope it just stopped
Old Oct 11, 2010 | 11:36 PM
hydrashocker's Avatar
hydrashocker
Do you have a "check engine" light on?
Old Oct 12, 2010 | 07:38 AM
buc2000's Avatar
buc2000
yes but it was on for a while but still running
Old Oct 12, 2010 | 07:41 AM
buc2000's Avatar
buc2000
if i take coil wire from distributor and insert plug and turn engine should i get spark ?
Old Oct 12, 2010 | 07:47 AM
buc2000's Avatar
buc2000
and i did pull wire fron no.2 cylinder and had good spark so does this mean i can rule out coil,crank sensor, broken timming chain ? i changed crank sensor. no codes either. getting plenty fuel too.
Old Oct 12, 2010 | 12:12 PM
SumAmerican
going back to the easy questions.. when attempting to start does it try to kick over at all?? Do you hear a fuel pump when its just in the "on" position. do you require a jump to even crank it??
Old Oct 12, 2010 | 12:34 PM
buc2000's Avatar
buc2000
no it does try to kick over all, yes i can here fuel pump and i wore battery down trying to start but i put on charger for a little while when i try to crank. should i try to jump witn another car ?
Old Oct 12, 2010 | 03:03 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the charger wont have enough juice to turn the truck over alone, the battery would have to be allowed to charge for a few hours before it would make a difference
