5.2 year difference question
Old Oct 13, 2010 | 07:08 PM
FearThis94's Avatar
FearThis94
Default 5.2 year difference question
Was wanting to know if a 95 5.2 jeep motor will work in a 98 5.2 durango. Would you have to swap harnesses? Thanks for any help
Old Oct 13, 2010 | 09:35 PM
IndyDurango's Avatar
IndyDurango
If the 95 is a Magnum... yes.
Swap ALL sensors for those you had on the Durango version.
IndyD
Old Oct 14, 2010 | 03:08 AM
FearThis94's Avatar
FearThis94
I thought all were magnums. Is there any way to tell?
Old Oct 14, 2010 | 09:19 AM
IndyDurango
5.2Ls are 318 CIs and have been around since the 70s so no.. not all 318s are Magnums.
The PCM will only look correctly for sensor input from the correct sensors from the Durango version of the Magnum (same as other Magnums but not necessarily the same sensor data being returned to the PCM.)
Old Oct 14, 2010 | 09:52 PM
hydrashocker's Avatar
hydrashocker
The engines were modified to Magnum:
1992 for the 5.2L
1993 for the 5.9L
http://en.wikipedia.org/wiki/Chrysler_LA_engine
Old Oct 14, 2010 | 11:39 PM
IndyDurango
Can't trust Wiki as accurate. I do not recall a 1992 Magnum. ???
IndyD
Old Oct 15, 2010 | 09:54 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i was too young in 92 to recall a magnum or not back then . . . but i dont trusk wiki articles usually either
however, allpar confirms it, 5.2 and 3.9 in 92, and 5.9 in 93
http://www.allpar.com/mopar/318.html all the way at the bottom
Old Oct 19, 2010 | 11:04 AM
hydrashocker
Ya,
I din't agree with the 1992 either and I think they all started in 1993. However I would go to a 1994 to 2003 just to make sure.
