01 dingo key wont turn
Old Oct 16, 2010 | 08:45 PM
Mistavicious's Avatar
Mistavicious
Default 01 dingo key wont turn
My 01 durango key wont turn. Out of the blue this started then quit then a year later same thing again. Now my ride is stuck out of town at my parents house. Does anyone know what the problem is? i'd tried hitting it with a malet and it didnt work!
Old Oct 16, 2010 | 09:27 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
is this a factory key?? or a copy? try a factory key, and preferably the newest (least used) one that you have see if its just a worn down key
Old Oct 16, 2010 | 10:17 PM
CtownChris's Avatar
CtownChris
Make sure it's in Park. My mother has called me on more than one occasion and she had not put the car in park. Oh brother.
Old Oct 16, 2010 | 10:32 PM
Mistavicious
Default Release button for 01 Durango
My 01 durango is stuck in the driveway. I cant get the key to turn so im wondering if there is a release button to put the truck in nuetral so I can push it out of the way
Last edited by Dans01Durango; Oct 18, 2010 at 09:54 AM. Reason: Moved post from seperate thread, seems like the same problem.
Old Oct 17, 2010 | 01:19 AM
IndyDurango's Avatar
IndyDurango
What did you do a year ago when it was happening? Obviously didn't fix it.
Old Oct 17, 2010 | 09:47 AM
shrpshtr325
THE ULTI-MOD
there is an ignition lock on the gear shift so that if the key doesnt turn you cannot shift it into gear, afaik there is no override for this 'safety feature'
Old Oct 18, 2010 | 09:35 AM
Dans01Durango's Avatar
Dans01Durango
Is the steering wheel turned at all? Can you wiggle the wheel to loosen the lock? Could be the wheel's turned and putting pressure on the locking mechanism.
Old Oct 18, 2010 | 04:39 PM
shrpshtr325
THE ULTI-MOD
**** dan, good point, i didnt even think of that
