Neutral safety switch
Old Oct 31, 2010 | 10:50 PM
hydrashocker's Avatar
hydrashocker
Couldn't find any close. There are some a while away however?
Old Nov 1, 2010 | 12:00 AM
master tech's Avatar
master tech
Site Moderator & Tech
PARK/NEUTRAL POSITION SWITCH CAV CIRCUIT FUNCTION
1 L10 20BR/LG BACK-UP LAMP FEED
2 T41 18BK/WT PARK/NEUTRAL POSITION SWITCH SENSE
3 L1 20VT/BK BACK-UP LAMP FEED
I don't know if this is what were looking for. If it something else let me know.
Old Nov 11, 2011 | 03:15 PM
Dman98's Avatar
Dman98
I found a compatible harness that's meant for 1996+ ford alternator, here"s a pic;
I purchased one for $6 and it fits perfectly
Old Nov 11, 2011 | 05:59 PM
Old_School's Avatar
Old_School
I had the same issue about a month or so ago....2 options, the stealership can get them for $45 bucks or go to a pick and pull. i went to the pick and pull and the woman gave me the connector.
The local pick and pull i use is about 45 mins away and i only get there myself once every few months but, if you still in need beginning of next month pm me and im sure i can get you one....
BTW when mine fired i just spliced the wires and put the ends in the switch...and wraped,held in place with electrical tape as a TEMP fix but, i stress TEMP if doing this.
Old Nov 11, 2011 | 10:00 PM
Dman98's Avatar
Dman98
Thanks, but paid $6 for a new one and since it's made for an alternator the wiring is heavier. Here's some pics for reference;
Old Nov 12, 2011 | 09:04 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
nice fine man, thanks for sharing.
Old Nov 12, 2011 | 09:12 AM
Dman98's Avatar
Dman98
Ur welcome.
Old Jan 4, 2013 | 11:11 PM
mikbai's Avatar
mikbai
where is this NSS located? Inside the pan or up near the shifter linkage?
Old Jan 5, 2013 | 07:37 AM
Old_School's Avatar
Old_School
Drivers side right under the linkage.
Old Oct 8, 2019 | 11:35 AM
Junkyard Junkie's Avatar
Junkyard Junkie
I know this is a very old thread, but there I was trying to find a solution to the same problem. I got the Ford alt. pigtail. It does fit, but the slots on harness are just a little off, which did not allow me to lock it in place. I filed off the tabs on the side of the switch and now it locks.
