asking those who know
Old Nov 6, 2010 | 11:16 PM
1998durango4x4's Avatar
1998durango4x4
New Member
Default asking those who know
98 durango abs and brake light on speedo doesnt work at all and the rear speed sensor is replaced the one that mounts on top of the differential and still doesnt work????? auto zone asked if it was 2 wheel abs or 4 wheel abs i only seen wires going to the back brakes so i told them 2 wheel abs? im frustrated as all get out im not a mechanic and need some help. oh and the heater doesnt work now it worked last winter and it is blowing cold air this go around.
Old Nov 6, 2010 | 11:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
The output sensor on the transmission is for the speed sensor. As far as the ABS, you need to pull codes. The problem could the module or an open wire and not a sensor. On the cooling system, make sure the radiator is full and if it is, the thermostat maybe stuck open. Replace it if it is.
Old Nov 6, 2010 | 11:40 PM
1998durango4x4
New Member
it was just in the shop for the overheating he replaced the t-stat and i just pulled it out again cuz it overheated and its working fine now he also flushed my raidiator and added new antifreeze to it would auto zone be able to run the codes on it i know the obd2 wont read it
Old Nov 6, 2010 | 11:43 PM
master tech
You need to find someone with a scanner that reads the other modules too, not just the PCM. If you know someone that has a DRB3 or works at a dealer, have them pull the codes for you.
Old Nov 6, 2010 | 11:56 PM
1998durango4x4
New Member
alright thanks ive got one more thought im going to try during this week when the dealer is open as for the heater idk whats going on with that do you know if my 98 durango 4x4 is 2 or 4 wheel abs maybe i bought the worng part
Old Nov 7, 2010 | 09:16 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the rear wheel speed sensor should be the same, i would try the transmission output sensor, on the drivers side of the transmission, idr how much it was when i had to change it on my old truck, but it wasnt much,
the heat if you took the t-stat out that is the same as it being stuck open and is at least part of the problem, the other issues could be a clogged heater core, or an air bubble in the system, needs to be burped any time you have to open it up you introduce air which must then be removed after you close everything back up. Or the blend door in the dash could be stuck on cool not allowing the heat from the heater core to get to the vents.
you can check if the heater core is clogged by feeling the hoses going into the dashboard, they should both be warm when the engine is warmed up, if only one of them is hot to the touch you have a clogged core
Old Nov 7, 2010 | 01:30 PM
hydrashocker's Avatar
hydrashocker
If you have 4 wheel ABS you will have sensors on the front wheel bearing on each side. It wouldn't matter as the rear sensor is the same on both models.
Replace the transmission output sensor.
Old Nov 7, 2010 | 02:54 PM
1998durango4x4
New Member
I went to Autozone this morning and bought the 4 wheel abs sensor and now everything is ok speedometer works and light is off now if I can get the heater working I'll check the hoses a lil later today
Old Nov 7, 2010 | 08:20 PM
hydrashocker
Start a new thread on the heater.
