How many miles on these plugs?
You can also press the brake peddle or head lights switch to ensure the residual power is out as well as the key turn.
You will know because when you start it the engine will be harder starting (Only the first time start up) you run for the 10-15 seconds without touching the gas then shut down, and start again, and you will hear a difference. You will not see anything. Just read the thread and follow the instructions. We all might say things a little different but it accomplishes the same result.
This is probably better but either way.
To reset your engine codes:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery.
Start but do not hit the throttle. Idle for about 10/15 seconds then turn off.
Restart the truck and drive as usual. It will take at least 12 starts and 48 miles to fully retune the computer. Hard Codes leave a shaddow for 40 full cold starts.
Its 10 seconds, release. Repeat three times. Totals 30 seconds.
