4X4 shifting problem
Old Nov 25, 2010 | 11:21 PM
Thax's Avatar
Thax
Default 4X4 shifting problem
Hey guys, I need help! My 2000 4.7 durango sport with a NV 231 transfer case is not shifting out of neutral! I put in 4HI and it shifted odd into 4HI almost like something got jammed into the plastic sliding piece with the shifter. I then put it into 2wd and the shifter lever was moving around alot , it is normally very solid . When I got back to my house I tried to move it around to see what was wrong with it, I went from 2wd to N to 4LO and back to N and now the shifter will not move at all . It almost seems like there is debris stuck in the shifting column or could this be a T-Case shifting linkage problem , let me know what you guys think . Im currently broken down with a non usable truck about 300 miles from my home due to the holiday so any help is appreciated.
Old Nov 25, 2010 | 11:47 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would get underneath and see if the linkage is somehow jammed, sounds to me like thats what the problem is.
Old Nov 26, 2010 | 02:47 PM
hydrashocker's Avatar
hydrashocker
Sounds like the linkage lost a coupler or bushing. Get under it like Sharps said.
Old Nov 26, 2010 | 06:19 PM
Thax's Avatar
Thax
yeah there is definatly a bushing missing , where would the coupler be? and how could i tell if is defective?
