I need a lil help
Old Dec 2, 2010 | 11:34 AM
jstorm28973's Avatar
jstorm28973
Default I need a lil help
I have a 99 dodge durango 5.9 w/ 46re trans and I keep getting p0505 iac A vehicle speed sensor not detected. am I supposed to change the iac motor or speed sensor? any advice would do.
Old Dec 2, 2010 | 12:44 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
P0505 Idle Air Ctrl Motor Circs
dont know where you got anything about a vss from that code, but its a problem with the IAC motor or a bad wire going to it in the harness, i would replace the motor
Old Dec 3, 2010 | 08:35 PM
hydrashocker's Avatar
hydrashocker
Sharps is correct:
Clean your Throttle Body https://dodgeforum.com/forum/1st-gen...ttle-body.html and get a new IAC sensor. Also clean your air filter and look for any obstructions like a mouse nest in the intake system.
BTW<------ Here is a link for the correct codes: https://dodgeforum.com/forum/1st-gen...ine-light.html
