Shake from Rear
Old Dec 7, 2010 | 09:56 PM
purveyor's Avatar
purveyor
Default Shake from Rear
After driving for about 30 miles on the freeway my ABS light turned on, I exited, stopped at the stop sign and took a left. As I turned left the car started shaking from the rear left a bit. It was like my left rear brakes were preventing me to go or something. Any ideas what this might be? Or has anybody experienced this type of situation before.
Thanks!
Old Dec 8, 2010 | 12:08 AM
hydrashocker's Avatar
hydrashocker
Sounds like you could have broken a clutch pack in the rear end if you have a Limited Slip rear differential.
The bevel springs can ware out and fatigue fracture. When they brake loose thye get thrown into the ABS sensor on the top of the differential taking it out and copper wires go everywhere as well as metal in the gears......BE CAREFUL!
https://dodgeforum.com/forum/1st-gen...lp-please.html
https://dodgeforum.com/forum/1st-gen...c-lok-lsd.html
This also happens when a clamp from the clutch packs snaps:
Old Dec 8, 2010 | 11:57 AM
purveyor's Avatar
purveyor
wow that sounds like quite a big job..How much would that cost to have done? I have a 02 5.9L durango...How would I know if I have a limited slip differential? Aslo how would I explain this to the shop..Everytime i take it to a shop they can not recreate the problem?...I've been to 3 already. How else could they check if this is the problem besides driving it for a long time. Sorry for the long post
Old Dec 8, 2010 | 03:12 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you open up the rear differential there will be pieces of the clutch packs/sensor sitting the bottom, the longer you drive it without fixing it the more damage you are doing and the more it will cost to fix
Old Dec 8, 2010 | 09:23 PM
hydrashocker
Cost for a rebuild is about $900 if the gears are good. If not add another $300. If you do it the cost is minimum maybe $400-$500.
Old Dec 9, 2010 | 09:36 PM
purveyor's Avatar
purveyor
Thanks everyone.... One more question, do you think it could be the u joint at all, when I put her into gear I hear a metal on metal noise
Old Dec 10, 2010 | 01:27 AM
hydrashocker
Most likely the backlash in the gears (pinion to ring gear) is excessive, when you place it into gear it "thunks". Again, open the inspection cover to confirm.
